Guillaume V.
belle surprise
un cable qui rend hommage aux casques de qualité, dans mon cas un hifiman ananda et un meze 99 classics (diamétre du corps de...
Cornelis H.
excellent product
i use the digirescue between my streamer and my dac. Fed by a Sbooster botw 5v power supply. The difference is much greater...
Thierry G.
Très moyen
Je précise que je n'ai pas encore testé le module, mais plusieurs choses m'interpellent au déballage.
1.Les...
ALLO DIGIONE SIGNATURE Lecteur réseau Raspberry Pi 4 DigiOne Signature Volumio pré-installé Noir - avis - Il y a 4 avis.
Joerg M.
Thank you Audiophonics for offering this product!
I'm really glad I bought the Allo DigiOne Signature!
Paired with a good DAC (I have the Topping E50), the sound is amazing.
Wonderful voices, generally excellent precision. - Fantastic!
I use a very good and very low-noise power supply (Allo Nirvana SMPS) for the streamer and the DAC. I assume the Allo Shanti, for example, could bring further improvements.
The speakers seem to exist even less to me, the spatial image has more depth. Everything seems more realistic. Fantastic even for live recordings.
I also have the predecessor (without signature, unfortunately no longer available). This already has amazing qualities. With signature it is actually even better.
The Allo DigiOne Signature is, in my opinion, a fantastic product and definitely worth every cent!
Stefano Z.
wonderful streamer
I really wanted to ear the difference from my PC to a real streamer, and I wanted that every euro I spent for a streamer was on the streamer performance (so no DAC attached, no bells and whistles). This IS it. I usually struggle to ear differences between DACs so I was so surprised when I played the first track through the digione sig. The staging, clarity, less fatiguing sound was a huge step forward. I am totally happy.
One CONS: the preinstalled volumio was not original, so not up-gradable, so I had to buy extra hardware to flash the drive again and the extra money spent for the volumio version was a waste. You are better off choosing the roopie version and flash whatever on your own. I bought it with Nirvana, for me the result is already super satisfying, I don't feel the need to go with shanti, but I don't even know what I may be still missing, only that I am fine like this.
Ian F.
Allo Digione SIgnature - RP4 version
Prompt service and delivery. I am using my Allo DS with a ADI-2 DAC FS and a set of Meze Empyrean headphones. Very satisfied with the pairing and the sound quality of the Allo DS.
I have previously used a RP4 and purchased a separate DAC hat, downloading Volumio and installing it, which is easy enough. This is an important point as my Allo DS arrived well packaged, but with no instructions what so ever. If I had no prior RP4 experience, it would have been a bit of a struggle.
Aurelio Germano T.
Svolge egregiamente il suo lavoro.
In realtà le stelle dovrebbero essere 4,5....nella mia configurazione il lettore meccanico Cyrus è ancora superiore come risultato sonoro, anche se non di molto. Può dipendere da molti fattori ed anche dal software installato(volumio) che d'altra parte è un' interfaccia molto intuitivo e facile da usare. Rapporto qualità prezzo comunque eccezionale ed ottimo apparecchio.
Dépourvu d'écran et d'interface de contrôle, ce lecteur ALLO DigiOne signature se pilote à...
