Cornelis H.
excellent product
i use the digirescue between my streamer and my dac. Fed by a Sbooster botw 5v power supply. The difference is much greater...
Thierry G.
Très moyen
Je précise que je n'ai pas encore testé le module, mais plusieurs choses m'interpellent au déballage.
1.Les...
Laszlo G.
Excellent as monoblocks
I bought 2 amps to use as monoblocks. I previously used an SMSL PA-X in stereo; it wasn't bad, but it wasn't good...
ALLO KALI Reclocker I2S FIFO Sparky SBC et Raspberry 44/48MHz 32bit 384kHZ - avis - Il y a 8 avis.
jb b.
new kernel issue in Volumio to decode mp3 and 24 bits!
Do you have any advice regarding the new kernel issue that blocks allo kali + piano to decode mp3 or 24bit files (play as white noise).... the 32 bit conversion trick is no good to me after trying to invest in a coherent and reliable system... if no better solution is to be found, at least updating the presentation of this product, would be a real "game change"...
Pedro Antonio C.
Very good
Working with Piano 2.1 the sound is really good. I recommend it
BL C.
Great product from Allo. Great service from Audiophonics
Works perfectly with Allo Piano 2.1. With Kali Piano is getting much closer to Allo Revolution. A good investment if you want to play with passive DAC RPI HAT.
I should mention how quickly Audiophonics had respond to my ordering; my Kali was shipped in less than 6 hours from order confirmation which is quite impressive!
Constantin C.
Metallic sound!
If you like metallic sound with a lot of details this is for you.
AUDIOPHONICS DAC I-Sabre ES9038Q2M sounds 10 times warmer without this reclocker.
Peter H.
Great sound!
I build a system consisting of a Rasperry Pi 2 (using PiCore Player), ALLO KALI Reclocker, DAC ES9038Q2M and linear power supply. The result is amazing, the sound is great (in general better and much more detailed compared to my previous sound card, a Sound Blaster X-Fi HD SB1240).
Claude T.
C'est le Top!
DAC ISabre ES9028Q2M, avec le reclocker Kali et l'alim linéaire régulée, cable Mogami 3104 en bi-cablage sur des Tannoy D700. C'est le top.
Je n'aurais jamais cru que mes CD étaient aussi bons.
Jean François B.
Bluffant !
J'étais un peu sceptique quant à l'amélioration que pourrait apporter ce reclocker. J'ai été bluffé. Je l'ai installé entre mon raspberry et mon dac I-Sabre DAC ES9018K2M J'ai énormément gagné dans la définition des aigus, les basses et médium sont encore plus propres et la scène musicale s'est agrandie, comme si les musiciens étaient plus "ecartés". La dynamique est elle aussi meilleure.
Un régal !
Joachim G.
Not worth the money
Sounds with Piano really synthetic like mismatched frequencies.
AUDIOPHONICS I-Sabre V2 DAC ES9023 TCXO sounds much much better for less money.
To our taste the Kali works very well with most of slaves DAC allowing them to deliver their full potential
Voici le KALI de ALLO, un Reclocker I2S FIFO 44 / 48MHz qui permet de traiter parfaitement les signaux numériques et les envoyer...
