michel H.
Retrofit de 2 caissons de basses Kliosch
Suite à l'achat de 2 caissons Klipsch hs ,j'ai procédé à leur rétrofit après adaptation de la caisse, par ces hp...
Eric B.
Bon dac,un peut cher..
En remplacement d'un Do100 pro,il y a effectivement du mieux : on perçois plus de détails dans la musique,image stéréo...
Rafael G.
Just great
ALLO SHANTI Alimentation Linéaire Régulée Double 5V 3A / 5V 1A - avis - Il y a 24 avis.
Frank T.
Le top qualité prix!
Bonjour, j ai acheté cette alimentation pour mon phono limetree 5v , j ai testé avec cable standard , c est deja bien ,puis avec un cable belden,iec iego or et bals schuko , c est encore mieux . Avec cable standard je mettrrais 4 etoiles et avec un cable meilleure 5 etoiles .belle finition , on gagne en silence ,donc details ,precision, en timbre,douceur,tenue, basse plus punchy , un bas medium plus epais , je la recommande vivement avec un cable digne !
Matthias E.
Happy it makes a great difference
I have a Chord mojo and a hifiberry dig+ pro. Before I was using a power bank, and there was a clear difference between coaxial and toslink, toslink sounded 3d but a little less decisive, and coaxial was more impactfull but 2d, now both inputs sound equally 3d, clearly there was some electrical noise coming through coaxial that affected the dac which by the way is not galvanically isolated and this psu solved the problem, I'm very happy with this result, in the future I plan on powering a Chord qutest and allo digione signature with this
Serge S.
Opens up the soundstage but may require burn-in
Still waiting to form my final opinion on the Shanti. I am powering a RPI4 via usb to my Ares II Dac.
Going from a wallwart to a powerbank was a revelation - reducing sibilance, increasing width and depth by making the background blacker. It also brought a more controlled, albeit lacking bass.
With the Shanti the bass is back but a bit closer to what you get with a wallwart - more of it but less controlled. The sound is more dynamic than a powerbank. You definitely get more details as well but this comes at the cost of of a more sibilant and somewhat fatiquing sound. I definitely turned down the volume by about 10db for prolonged listening.
Again, I want to stress this is after less about10 hrs of listening.
I will continue listening and burning in the Shanti and then amend my review to reflect my final observations.
Janis P.
Allo Shanti
Significant sonic upgrade to any Hi-Fi gear.
Yannick M.
alimentation très efficace
sur un couple Raspberry + Allo Boss, ça fonctionne vraiment très bien.
Quel dommage que Allo ne la propose plus !
Mais bizarrement, elle est toujours apparemment disponible ici
https://www.allo.com/sparky/shanti.html
mais pas là
https://www.allo.com/sparky-eu/shanti.html
Question à Audiophonics :
pourra-t-on espérer une nouvelle disponibilité sur ce produit dans l'avenir ?
ou alors un produit de remplacement (éventuellement développé par vous-mêmes) ?
cdt
Cette alimentation est vraisemblablement définitivement arrêtée ...
Olivier S.
Pour recepteur SDR radioammateur
J'ai acquis deux alimentations dans le cadre d'un projet dit de websdr. Il s'agit de récepteur d'ondes radio en ligne.
Ces petits bijoux me permettent d'alimenter deux redpitaya 122-16 sur la sortie 3A et deux AIRSPY sur la sortie 1A.
La qualité est indéniable. Par contre ont aurait aimer voir des ailettes de refroidissement.
En effet, nos récepteurs tournent 24h/24. L'augmentation de la durée de vie par un meilleur refroidissement serait un réel plus.
Mais sinon, les niveaux de bruit annoncés et la stabilité sont bon.
Henri V.
Bons résultats à bon compte
Une alimentation linéaire qui remplace avantageusement 2 alimentations à découpage.
Les alimentations à découpage même les plus "silencieuses" ont tendance à polluer les appareils connectées sur le même réseau électrique.
Le résultat est variable d'un appareil à l'autre mais toujours positif.
Vivement conseillé !
Christian R.
Des améliorations très audibles
J'ai acquis cette alimentation pour mon streamer Node 2i tweaké par une carte polonaise. Par rapport à l'alimentation fournie avec la carte, l'amélioration apportée par l'Allo Shanti est immédiate, et encore plus audible après un rodage de quelques heures. Des micro-informations sont plus nettes, l'ensemble du son est plus doux. C'est la meilleure alimentation que j'aie acquise chez Audiophonics jusqu'à présent.
Christian R.
Excellente à tous points de vue
Excellente dès qu'elle est reliée à mon Node 2i,, utilisé comme transport, elle révèle toutes ses qualités après une bonne période de rodage (chez moi 30 heures) : douceur, précision, silence. Je pourrais regretter les câbles de liaison solidaires de l'appareil, mais tant pis, je me suis consolé avec un câble secteur de marque. Cette alimentation vaut largement son prix. Encore merci à Audiophonics qui me l'a conseillée !
Kenneth m.
Super good for the price...
Works really well with the 3 amp. output for my Chord Qutest, and the 1 amp. output for my TP-Link TL-SG105E 5-Port Switch...
Harry P.
It works
Hooked up to Allo USBridge Signature...nice improvement, more open, clear and calm....recommended!
Gregory P.
Much better than a powerbank
I used to power my DACs with a 20,000 mA powerbank. Although I had a black background, I was not fully satisfied. My main complain was a lack of dynamism. After having read everything I could on Shanti, I gave it a try and... I really do not regret it. It is much much better. The sound is much more dynamic, everything has a better texture, trebles are smoother and I have more resolutions. Bass are more powerful too and dryer (read better). Imaging is better. It is as quiet (some say more due to the noise produced by the chemical reactions in the powerbank (maybe, I don't know)) as a powerbank. But, the sound is overall way better hence the pleasure to listen music.
 (3)
Dario G.
Très efficace.
Produits très efficace, pourtant partie d'une alimentation spécifique..
Ce produit recule encore la distorsion, meilleure aération, douceur et réalisme des timbres.
La basse de la source...
Dominique G.
ALLO SHANTI
Alimentation développée pour le streamer Allousbridge.
Très silencieuse et indispensable pour exploiter pleinement le streamer. Juste un petit reproche, une sortie 5 volts sur châssis type aviation aurait été parfaite pour mettre un câble de qualité.
Michel R.
excellent produit!!
elle fait le job, et plus que bien!!silence total et efficace,tout ce qu'on lui demande,allez pour etre pointilleux,peut etre les cables des sorties font un peu cheap et auraient merite un aspect plus solide,meme moyennement un supplement..sinon,excellent produit comme tout ce qui sort de chez audiophonics
Aurelio Germano T.
Alimentatore di alta qualità.
Costruzione e funzionamento impeccabili.
Indispensabile per Allo Signature + Rasp.
Göran A.
The best powersupply
I bought this for my, Allo sign usb, mediaplayer.
The powersupply is absolutly quiet and runs very cool, barly over the room temperature.
I am very pleased with my buy, and can rekommend it for anyone who needs a 5v supply.
Paul H.
Excellent value for money, very low noise.
David B.
Excellent produit
Rien à reprocher à cette alimentation de très grande qualité, qui fait son boulot mieux que bien.
Jan T.
Very good product
Ik ordered the Shanti at the beginning of september and received the order in 3 days in the Netherlands.
I use my Shanti supply on a Raspberry Pi 4 and a Allo Digione Signature board on top of it.
It sounds wonderfull and tooks the sound quality to the highest level.
Very smooth en open sound with no sharpness.
I also ordered a Shanti for a friend of mine on the 14thd of october. The delivery should be at the beginning of november. Unfortunately the Shanti has not delivered yet.
antoine L.
alimentation ALLO SHANTI
d’abord physiquement, l'alimentation est trois fois plus importante que mon lecteur réseau Lindemann Limetree Bridge, ce lecteur réseau a t il besoin d'une telle alimentation,.. en attendant seul le résultat compte,
et le résultat est flagrant, les notes ce détachent mieux les unes des autres, meilleur positionnement des intervenants, plus de précision sur la scène sonore, plus de micros informations, bref, avantager l'alimentation c'est passer au dessus du lecteur de base, monter d'un cran facilement, aller sur un autre lecteur qui aurait été bien plus coûteux,
la base de mon écoute est un casque audeze LCD4, que l'on aime ou pas ce casque, en attendant si l'on place une petite pièce de un centime sous les pieds d'un lecteur la différence se fait entendre, il ne laisse rien passer à condition que tout l'ensemble soit bien réglé,
ce n'est pas ma première alimentation dont j'ai fait achat chez Audiophonics, la première était pour le iFI ican pro qui a apportée le même résultat, Audiophonics ont de bon produits, avec des personnes toujours dispos à la moindre demande, merci
Jan R. S.
Jan R. Smit
A very nice power supply. Quiet, also mechanically.
Tim C.
Excellent linear power supply
This is a real bargain! Currently using it with two Pro-Ject Audio products (the S2 DAC and the S2 headphone amp). Sound quality significantly improved and, due to the low amp demand of the two S2 boxes, the Shanti really never goes beyond mildly warm :-)
I think the use of super capacitors makes a big difference.
OK...it's a long box but you don't have to look at!
Initial order was dead on arrival - I think Allo have had some quality control issues - but Audiophonics replaced this straight away. Excellent customer service from Audiophonics.
This LPS is HIGHLY recommended. I did try it with my Pi/Digione combo, and it worked just fine. However, I got better results by continuing to power the Pi/Digione using an iFi 5v power supply and dedicating the Shanti to the DAC/Amp S2 boxes. Your mileage might vary....as ever.
Marek V.
Allo Shanti
It's my first linear source and I can't come out of wonder. Excellent product. He moved Allo USBridge to the next level.
Everything has improved.Separation of tools, depth, location in space .....
I'm really impressed.
I recommend to all.
Harald B.
Make good things better
I'm a huge fan of the Allo Boss Dac. I like his musicality. Pace, rhythm and timing are top. I have tried different power supplies, LPS,Ifi etc. I became best results with two supplies. Pi and Boss separate powered. Now I use a Allo Shanti and it's the best i tried until now. The music becomes more natural, less grainy, less sharpness. And this without loosing his musicality. I detected only benefits and no disadvantage.
One power supply and you are done. Imho a must have, if you like the Boss dac.
La Allo Shanti est une alimentation linéaire régulée disposant d'une double sortie 5V 3A et 5V 1A. Elle est...
