John F.
Crystal clear and transparent.
In short a very capable, clean and clear monoblock amplifier and even when turned up high with no music playing it is dead...
John F.
Very capable dac/preamp
I have listened to this dac and preamp for over two weeks now and can say that the dual rohm chip latest version is very smooth...
Mikael M.
J'oubliais
Bizarrement , ce d'ongle et UAPP ne font pas bon ménage .
( Utilisation Tidal ) .
Le son est mieux en passant...
AUDIO-GD DA-7 MKI 2023 Module DAC R2R 24Bit 384kHz - avis - Il y a 7 avis.
Panos M.
Its more my personal taste
I am doing a lot of DIY, the last DAC was based on an ES9038Pro in stereo. This one is different. I coupled it with a tube buffer and an XMOS interface, it worked with no issues and in my taste more musical than the ES. For the cost its a no-brainer.
Boy H.
Awesome!
Got it combined with the Amanero Combo768 interface (i2s). Sounds better than my Topping D30Pro.
Henrik E.
Beats the sigma-delta bunch.
Formerly, i made a project with the ESS flagship ES9039 with reclocker, FIR reconstructor, etc, very ambitious. It was OK, the dynamics and clarity superb, but was a bit too... well over the top, so to speak.
I bought two of these R2R-boards, and just used them as replacements for the ESS chip. I had a multi bit DAC some 15 years, and since then I can't really be friends with the sigma delta types.
With these boards it's like coming home - but with the house freshly painted. The typical superb representation of nuances that renders poetry to the listening session is there. But it's even better than the old PCM1704 I had. These new boards have something the PCM1704 didn't have; a CPLD that cancels away resistor mismatch. This is the new brave DAC world. The old sigma delta devices, used for so many years, days are counted. In the future all audiophile DAC's will be this kind of intelligent R2R design, but probably packaged in one chip.
But the images of how to connect the boards are a bit misleading. The single ended OP-amp schematic is not very recommendable.
I'm giving it just four stars, since I don't really have something to campare it with, at least not other brands of the same type.
Theodore A.
amazing
I built my own DAC based on this. It is an amazing piece, worthing every penny... If you can built a DAC use this R2R, unbeatable for price
Adam S.
this is brilliant
made a dac with 3 r2r bords and passive output without opamps ,tried with opamps it sounded dull and bad compared with my dddac, with passive output it beats ny dddac and my friends metrum pavane and a denafrips, they just got beated very bad, the psu used is a 3 stage psu with emi filters and lt3045 in the last stage, lm1084 in first stage and lf80 in second stage, and a lot af b4 15000uf caps in indput and before lt3045, this is the best dac i ever heard
Raffaele V.
AUDIO-GD DA7 corretto
Not simple but not complicated either. You need to pay attention to the wiring and power supplies and I highly recommend the original ones.
One day of work, triple checking everything, It pretty much worked first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future. Non semplice ma neanche complicato. Bisogna porre attenzione ai cablaggi e alle alimentazioni che consiglio vivamente le sue originali.
Un giorno di lavoro, ricontrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcuni accorgimenti che intallerò in futuro.
Raffaele V.
AUDIO-GD DA-7 Kit
Not simple but not complicated either. You need to pay attention to the cams and feeds and I highly recommend them.
one day of work, rechecking everything three times, It practically worked the first time. The sound is basically excellent, but can be improved with some adjustments that I will install in the future.
Non semplice ma neanche complicato. Bisogna porre anttenzione ai camlaggi e alle alimentazioni che consiglio vivamente le sue.
un giorno di lavoro, riconytrollando tutto tre volte, Ha praticamente funzionato al primo colpo. Il suono, di base ottimo, ma migliorabile con alcunio accorgimenti che intallerò in futuro.
Le module DA-7 MKI 2023 de chez Audio-GD embarque un DAC 24 bit basé sur réseau...
