Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
AUDIOPHONICS CANARE Câble Numérique Coaxial Ultra Coax 75 Ohm BNC-BNC 1m - avis - Il y a 3 avis.
Stefano G.
Good
I am connecting a Oppo BDP 105 to a Lector Digicode s-192. Compaired with my previous 20 euro rca cable, the music is more transparent and the bass are more punchy.
I am very happy.
Ivaylo K.
Good product
Just like in one of the previous comment I use this cable in the same situation - between Allo DigiOne and a Chord Qutest - it works well, it is also very well crafted - although it is a bit stiff.
Istvan D.
Prefect to connect DigiOne Signature player and Chord Qutest DAC
I use it between DigiOne Signature player and Chord Qutest DAC.
It is a prefect match to the task, I tried up to 24bit/192KHz without any issue (maybe good for higher speeds but I does not have music to try). Not cheap but performs well, connectors are strong, looks/feels like a quality product.
Ce câble Coaxial Ultra Coax 75 Ohm avec connecteurs BNC mâles est assemblé en France par Audiophonics, avec des...
