Lennart H.
Eric H.
Bonne qualité
Bon rapport qualité prix : fait le job !
Eric H.
Excellent câble
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
AUDIOPHONICS DIGIRESCUE Module Reclocker SPDIF Optique Coaxial Isolation Galvanique 24bit 192kHz - avis - Il y a 2 avis.
Joris J.
Addition
This text in the description above: “ The DAC connected to the module will then receive the audio signal on its optical input." this is only true when a optical cable is used between reclocker and DAC. This reclocker can also be used as a optical to coax converter. Both optical as coaxial output sockets of the reclocker give the output signal.
Joris J.
Superb reclocker
I use optical only, so used only the reclocker of this device (galvanic separation already exists by optical connection). Sound improvement was signifanct and even astonishing when using a regulated power supply with LT3045 in it.
Thanks to Audiophonic for bringing out this product!
Ce module reclocker Audiophonics DIGIRescue a été conçu en association avec Ian Canada. Il permet, grâce...
