Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
AUDIOPHONICS LPSU100 Alimentation stabilisée linéaire 2x 5V 6.25A 100W - avis - Il y a 4 avis.
Siniša B.
Outstanding LPS
I previously upgraded to a switched power supply, but moving to this incredible LPS (TERADAK) linear power supply has been a game changer. The improvement is absolutely worth it. The soundstage has become wider and more spacious, with tighter, more defined bass. Overall, an impressive upgrade. 5 stars!
Nuno Miguel J.
realy good LPSU
After trying Nirvana and Shanti, I``ve never tought that this would made a BIG improvement in SQ. Clear and transparent midle and highs, dynamic, creamy and tight bass e bigger sound stage. Super analogic and non fatigue sound. The best LPSU for your Revolution and Signature combo from Allow
 (3)
Goetz S.
TOP SERVICE
The description started with reference to output GX 12. This was wrong. It is actually a GX 16 output. The error has now been corrected. Due to the wrong description, I ordered high-quality GX 12 to DC 5.5 / 2.5 cables from another company, which logically did not fit.
The service that followed was really outstanding.
I was able to send the power supply back (with my cables), the outputs were adapted to my cables, tested and sent back to me.
Shipping there and back was completely free. First class service and thank you for that.
The power supply itself is great and does what it should.
 (3)
William l.
2x 5vdc psu 100W very nice quality!!
After building several linear psu's myself, which all became very hot, I bought this great power supply, and It doesn't even warm up a little with the same load!! very happy with it, price is also acceptable good build quality ( I assume TerraDak is the manufacturer?
 (3)
