Marc A.
Parfait
Mon lecteur réseau Teac NT 505 X possède une sortie casque 3,5mm à 4 pôles. Hors tous les jacks proposés en 3,5mm sont en 3...
Fabian b.
superbe tube .fonctionnent très bien sur un Cayin cs150
.j aimerais savoir si ils sont disponible en quad appairés. Merci pour vos réponses..
alexandre G.
excellent
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une...
AUDIOPHONICS LPSU25 Alimentation Linéaire régulée Filtre EMI RFI 9V 2A 25VA - avis - Il y a 13 avis.
Rupert S.
HOT
It gets very hot and uses twice the energy the little Meanwell PSU uses. I frankly cannot heat much of a difference in my setup. Overall not worth it for me.
Audiophonics Hypex amp, EVO DAC, PMC TwentyFive.23
Cezary G.
Power supply for TAGA Harmony DA-400
Bought to improve the DAC power supply, instead of the default switching power supply (which wasn't terrible by the way).
The build quality (I'm assuming it's from China) is good, with a solid case that also does the job of a heatsink for controlling MOS-FET.
The sound became more structured, and less lively (as it happens with switching power supplies) but more accurate, and the soundstage (space) gained in openness.
I will still experiment with AC and DC power cables and increase the capacitance of the capacitors at the output of the power supply.
Guy H.
Excellent !
Belle esthétique et finition.
Silencieuse.
Livraison rapide et bien emballé.
Je recommande
Kęstutis S.
Very good
This replaced an IfI iPower 9V for my SOTM-200-Neo streamer. First of all - the make is solid and robust and gives an impression of reliability and safety. Secondly, the sound seems to have improved - the space enhanced, the bass more controlled, and the highs unvealed. Will buy a 12V version for my DAC when the finances allow :).
Kęstutis S.
Very good
Andrea T.
excellent
Bought to power the Sotm 200 streamer, it increases its performance in all fields...
Robust construction and excellent materials.
Recommended
Alain H.
Excellent
Améliore nettement le rendu sonore de mon lecteur réseau sotM.
Merci à l'équipe Audiophonics pour ses belles réalisations à un prix très correct.
Daniel B.
Le complément indispensable de l'EVO DAC
Vous voulez sublimer votre EVO DAC ?
N'hésitez plus !
Cette alimentation permet d'atteindre le nirvana, tout simplement :-)
Jean Luc m.
Indispensable
Bonjour, restant sur ma faim du resultat d’une alim à découpage
Ifi audio très faible bruit je suis passé à cette alim linéaire.
Résultat, virez les alims à découpage,en terme de musicalité rien ne vaut une bonne alimentation linéaire.
L’alimentation linéaire Audiophonics apporte vraiment un plus à tous les niveaux, son plus doux dans les hauts médiums, plus de transparence, grave plus intense et mieux tenu..aigus plus fins et nuancés.très grande netteté des médiums.
Image stéréo vraiment en trois dimensions et excellente focalisation
des instruments dans l’espace.
Bref,que du bon.
Bravo à vous pour cette alimentation qui pour une somme modique apporte un vrai plus en terme de musicalité.
Pour conclure je me suis rendu sur le site de mon lecteur réseau
Sotm et il propose une alim sûrement très bonne mais à un prix
qui frise l’indécence , un peu plus de 600 €, plus chère que le lecteur.
Cordialement
Jean-Michel P.
Un + vraiment appréciable
En remplacement de l'alimentation fournie en standard avec mon 3D LAB Nano Transport Sonata V5...
Le gain se situe au niveau l'attaque des sons. Encore plus nette et plus propre !
(sinon, comme Arnaud, je trouve que la LED éclaire un peu trop :) )
Carlos Alberto Rodrigues T.
Paired with Aune X8 Magic DAC
No doubt there is an audible difference comparing to the use of stock power adapter that comes with Aune X8 Magic DAC. Chosed this power supply instead of the Aune XP2 or XP3 ones because I think this one from Audiophonics is better engineered. Anyway, the result is the improving of all tonalities clarity through the audible spectrum. Very nice job Audiophonics!
Mathieu w.
Amelioration
En plaçant cette alimentation sur un rippeur INUOS j'ai gagné en bande passante en précision Redécouvertes de certains titres favoris
Arnaud F.
Apporte de la sérénité à mon ensemble
Grâce à l'alimentation, mon ensemble avec Evo-sabre a un rendu sonore plus doux, avec des silences plus vrais.
Les attaques de sons et également leurs fins sont plus définis.
Tout cela permet un meilleur rendu des graves tout comme des médiums et aigus.
L'alimentation semble très bine fabriquée et donne une belle impression de qualité dommage que la diode soit si lumineuse.
Voici l'alimentation régulée faible bruit 9V 2A audiophile pour tout appareil fonctionnant sous 9V DC.
