Gérard B.
Buffer Audio type YAQIN SD-CD3
Après des écoutes attentive et relaxante, pour bonifier votre source que ce soit un CD, une platine Vinyle ou un DAC Bluetooth...
Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Marco R.
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio...
DAYTON AUDIO ND65-4 Haut-Parleur Large Bande Aluminium 15W 4 Ohm 83dB 85Hz - 20kHz Ø6.3cm - avis - Il y a 2 avis.
Alvaro S.
Muy interesante
Lo he usado en una cajita de casi 2L, sintonizando el bass-reflex con ayuda de WinISD. La gráfica de la simulación era alentadora, y de hecho el resultado es bastante sorprendente sobretodo teniendo en cuenta su tamaño.
Günter L.
best small speaker for radioprojects
I recieved th speaker and tested it within my project. It sounds very good and has a real good performance. I use it without any filter together with a justboom amp.
Avec son moteur faible distorsion monté sur aimant neodyme, son design haute excursion et sa construction avec diaphragme & cone aluminium...
