Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
DD MFI09S Câble USB-C Mâle vers Lightning Mâle OTG Argent / Cuivre OFC 10cm - avis - Il y a 1 avis.
Martin A.
Bad quality
I'm writing this, because this is the second DDHIFI item that quit working after some months of use. The lightning part will come loose from its socket, very disappointed of DDHIFI build quality, the sound was great though.
Le câble USB-C vers Lightning  DD MFi09S profite d'une conception parfaitement maîtrisée, utilisant...
