Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
E1DA COSMOS GRADE A ADC Symétrique ES9822Pro 32bit 384kHz - avis - Il y a 1 avis.
jf a.
Great product !
If you want to seriously get into measurement but you can not afford kilos of money, go buy it !
Be aware of the Zin, for small signal it starts around 600Ohm, but THD+N of 140dB is there !
With a really good osc (janascard dot cz, another great piece of hardware) I don't have any harmonic ! just noise floor around -140dBFS (with 16384 fft points).
only 2 minor concerns:
- I hate usb-C , it is not harsh enough...
- same for the jack if you want to convert amplifier outputs
So it's really a great product !
E1DA propose avec le Cosmos un ADC symétrique high-end, dont l'étage de conversion analogique/numérique se...
