Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
EIZZ EZ-213 Connecteurs XLR 3 Pôles Mâle et Femelle Plaqué Rhodium Ø10mm Noir (La paire) - avis - Il y a 1 avis.
Theodore A.
Very good connector
Sound is really good, not however like the top connectors, there is a difference. For the money however the sound worths every penny.
My problem is that I used 10mm cable and the fixing screws, either sunk (had to put extra sleeve to reach 11mm) or in two cases the plastic where the screws reside was broken. Its a pity. My recommendation to EIZZ. Put an extra hardened plastic ring where the screws will reside and make them a little longer.
Cette paire de connecteurs XLR EIZZ EZ-213 est composée d'un connecteur XLR mâle et d'un connecteur XLR femelle. Ils...
