Juha K.
Excellent
This amplifier could be described as very versatile for different music genres. Purifi has never disappointed my own ears. This...
Eric H.
Fiches RCA de qualités
Très bonnes prises RCA de très bonnes qualités.
Le seul bémol c’est la soudure de la masse sur le corps qui n’est pas...
Eric H.
Excellents condensateurs
3ème commande, pour mes amplis: super sonorité
ELECAUDIO CS-361B Câble Secteur OCC PTFE 3x2.5mm² Double blindage Ø17mm - avis - Il y a 30 avis.
Claus O.
The best purchase I've made in many years
I have heard many more expensive power cables and there has been an improvement in the sound, but this cable is to date the one that has given me the biggest improvement for the least money, in comparison to the Swedish SUPRA power cable which I have paid significantly more money for does not have the improvement in the sound at all, I immediately experienced an improvement in the bass, midrange and upper treble and 3D was fantastic, the only negative thing I can say is that it had a little emphasis in the upper treble, I could not hear that before... I do not hesitate to recommend this cable to others who may be skeptical about whether there is really anything to gain from power cables mounted cable with Oyaide plug P-046E & C-079. they were so fantastic that I compared it with the Power cable from LessLoss which costs 10 times the price, here LessLoss was a little better, but the tonal character was similar
regards Claus Olsen
Uwe G.
Topp Kabel
Ein Kabel ohne Kompromisse.
Konfektioniert mit Kupfer vergoldeten Steckern ein Muss.
Krzysztof M.
Perfect!
Produit conforme à la description, livraison rapide et sûre. Merci pour une transaction réussie!
Didier T.
Excellente surprise... si on lui donne le temps de s'épanouir !
2 mètres de CS-361B exploités en entrée d'un BADA 6610 alimentant ma box, mon Node 2i (via carte PD Creativ + bloc Shanti) et mes Nuprimes Dac 9X & STA 9X).
Ce CS-361B est très déconcertant pour ne pas dire décevant durant les premiers instants, contribuant à une courbe de réponse "en cloche", très centrée "medium" avec un effet bouché et sans vie aux deux extrémités.
M'appuyant sur les précédents avis, et s'il commence à se réveiller entre 40 et 50 heures, j'ai laissé sous tension l'ensemble des maillons durant près de 100 heures (non sans streamer en boucle) avant d'envisager avis "sérieux".
Arrivé à ce terme, le résultat est fait d'ouverture, fluidité aération sans aucune dureté : c'est très convainquant !
Au-delà de sa très belle texture sur les voix (déjà mentionnée par ailleurs), mais pas que, je lui trouve surtout dans mon cas une homogénéité, pour ne pas dire une intégrité tonale sur l'ensemble du spectre : je constate qu'aucun segment du spectre particulier n'est favorisé au détriment d'un autre.
Guitariste possédant mon propre studio avec plusieurs (jolies) guitares (et leurs amplis), batterie et clavier, mes tympans m'invitent à rendre à ce câble secteur ce qui lui revient, c'est à dire sa capacité à éclairer (étirer ?) la restitution sans écraser la dynamique.
Au contraire, je trouve qu'il contribue très probablement à faire vivre les micro-détails avec subtilité sans rien dénaturer.
De telle sorte qu'il me donne la sensation d'être sinon immergé au milieu des musiciens, du moins au premier rang du concert en pouvant savourer l'effet tri-dimentionnel du spectacle musical proposé.
Surtout, il ne me donne pas envie de découper les décibels en quatre sur "mon aigue ceci, mon medium cela et mon grave machin" : cet ELECAUDIO CS-361B me donne tout simplement l'effet de contribuer à faire passer la musique avec sincérité.
Et, oui, comme le bon vin, il faut lui donner sa chance sans "sur-réagir" dès les première minutes...
Pour conclure concernant sa construction, je lui trouve bcp d'atouts techniques et sa mise en oeuvre, si elle demande un minimum de rigueur et de précaution, ne présente aucune difficulté.
Enfin, sa relative souplesse (ou raideur, c'est selon), ne pose pas de difficulté particulière dans son ergonomie.
Didier
 (3)
SERGE B.
Un excellent investissement !
J'ai une installation iFi de tout premier ordre (lecteur Cyrus, DAC Wattson avec switch EE8, préampli et ampli à lampes Yves Cochet, enceintes Ilumnia Magister Mk2) et bien que sceptique, j'ai essayé de changer les câbles d'alimentation pour voir si cela améliorait la qualité sonore.
J'ai d'abord utilisé de l'Olflex 110 CY 3 x 1.5 mm avec des prises Elecaudio PS24RA et des IEC Viborg en cuivre rouge . A ma très grande surprise le son a beaucoup gagné en détails, précision et ampleur. J'ai retesté en aveugle avec ma femme avec Ce câble-ci en alimentation de mes sources et le résultat est encore meilleur... Ma femme l'a tout de suite remarqué sans être au courant. Je ne suis pas ingénieur et je me l'explique pas mais le résultat est là et cela sans investir des sommes phénoménales...
Le câble est très gros (18 mm) mais assez souple et bien conçu si ce n'est au niveau des couleurs dont aucune ne correspond au neutre ! Dommage... Le fil de drain du blindage est très utile pour le raccorder à la masse ce qui est indispensable pour un blindage efficace.
Bref, un excellent investissement qui en vaut la peine
laurent C.
La gaine est énorme ! mais les cables intérieure sont très souples et bien isolés ce qui pose problème au montage s'est surtout la gaine d'un diamètre imposant, a par cela le montage se fait facilement. J'utilise ce cable sur une barrette secteur Taga harmony. C'est limage de mon TV oled qui s'est amélioré (définition, précision et clarté) pour le son, plus d'ampleur dans le grave ça reste précis et pas baveux pour autant il ma semblé que l'aigu manquai un peut de pèche ! la définition générale reste douce pas agressive du tout avec une énergie qui fais plaisir. Le cable est monté avec des connecteurs de marque VIBORG en cuivre pur. J'ai relier la petite stresse sur la cable de terre seulement coté connecteur schuko
Dejan V.
ça vaut le coup ça vaut le coup
Monté avec des bouchons Viborg aux premiers bruits la mandibule touchait le sol. On dit qu’il faut des heures de travail pour montrer ses vraies couleurs.
Je n'ai pas beaucoup d'expérience avec les câbles, mais ce fil "fait" un meilleur son.
Eelco R.
It actually works
I also was sceptical about what to expect but the cable actually makes a difference. It’s huge (my son was jokingly calling it the water-hose) and you have to purchase appropriate plugs.
Once connected, I immediately noticed a difference in detail and clarity. Also the spacing seems improved. The highs are a bit more prominent and that’s getting used to. But only used the cable for about 8 hours so have to see how this progresses.
Davor F.
Just Great
From the first minutes of powering with this cable i was a little sceptical if it's gonna be something good of him but you must put youre suspicions aside and let it play for about 30 or more hours.After 50 hours of powering it becomes revealing as hell in a good way,stage opens up,details in abundance and bass is more defined.Cable is worth every cent, you wont regret it if you go for it.
Michel G.
Une réelle amélioration du son
Tout d'abord impressionné par la taille de section du cable, on dirait un tuyau d'arrosage. Mais une fois monté avec des prises de qualités, les 3m de câbles ont réellement apporter un plus par rapport à mes tornado dont j'étais et je suis satisfait.
Le montage n'a pas été plus compliqué qu'avec un autre câble de moindre section
Jonathan K.
Rapport Q/P et Réalisme impressionnant
J'ai tenté ma chance sur ce câble pour remplacer le feu très célèbre (enfin sur ce site) WM Audio Tornado.
Ma configuration est la suivante :
- Platine REGA RP6 + Hana SL
- Gold Note PH5 + PSU5
- REGA brio (dernière génération)
- Mulidine Allegretto V4
J'ai confectionné le cable avec des connectiques VIBORG pur cuivre plaqué or/argent. Il alimente le REGA brio.
Tout d'abord, on constate dès les premières minutes une très belle clarté et un aigu qui respire. Il faut cependant attendre une bonne cinquantaine d'heures pour que la dynamique soit meilleur et que les basses soient mieux "digérées".
Après une bonne centaine d'heures, voilà mon avis :
Points positifs :
- Aigu très détaillé avec beaucoup d'air. J'entends plus de choses qu'avec le WM audio. Garde un souci permenant de douceur même en montant le son !
- Un médium parfait (et là c'est vraiment très impressionant, tellement réaliste sur les voix humaines piano etc...)
- Très bon graves mais on peut faire mieux selon moi.
- Bonne aération et cohérance globale.
- et encore ce médium ... pardon je l'ai déjà dit :)
- très transparent et neutre, chaque enregistrement que j'ai écouté m'a laissé une impression de réalisme et de justesse.
- Très flexible et donc pas besoin d'acheter un mètre et demie comme le WM audio.
Points négatifs :
- Il est moins dynamique que le WM Audio Tornado à niveau égale (j'écoute à environ 9h avec le WM alors que je suis à 9h45 avec le ELECAUDIO)
Avec ce câble, ELECAUDIO réalise un coup de maitre !
Raymond M.
Quelle qualité !!!
Avec ces 5m d’ElecAudio CS-361B et un connecteur Viborg VE512R, j’ai confectionné une ‘rallonge de luxe’ pour raccorder mon installation PC-HIFI à la terre. La prise de proximité en étant dépourvue. Mon ‘problème de riche’ c’est que j’ai tellement investi en matériel (pc, hifi, câbles) ‘high-end’ que je crois avoir atteint un tel niveau difficilement améliorable… Mais au moins ce qui est sûr c’est qu’une telle ‘rallonge’ ne peut pas faire l’inverse, car c’est superbe au niveau qualité. Curieusement j’ai la sensation que la visualisation de mes photos s’est améliorée avec des tons plus contrastés… Côté audio… Mais au bout d’un moment on rentre dans le subjectif…
Andoni G.
Good cable
Es un cable muy grueso y difícil de doblar. La calidad percibida es superior
Cedric J.
Le bon choix.
Câble de gros diamètre mais très souple et maniable. La mise en oeuvre et minutieuse "grâce" aux téflon entourant les 3 groupes de brins des sections phase et neutre.. un coup de kutter delicat dans la longueur facilité la tâche...
Très bon câble neutre est ouvert... Meilleur ou différent, dans sa neutralité et fidélité, je l' avoués que mon oyaide que je trouve très bon .
Cedric J.
Très bon
Un câble de fort diamètre mais souple et maniable. Le téflon entourant chaque groupe de brins de chaque section colle bien aux fils. Pour s' en débarrasser, je le coupe délicatement dans la longueur et c' est plus facile a défaire.
Aux premières écoutes, bof, bof, rien de transcendant, voir plat...
Mais déjà une dizaine d' heures de chauffe et il commence à démontrer son potentiel très neutre, offrant une belle ouverture, une très bonne image stéréo, la musique est très proche de ce qu' elle est sensée être.
Je le recommande , surtout a ce tarif !
Claude T.
Surprenant
Une écoute géniale avec ce câble, et pourtant ce n'est pas le premier que j'ai acheté.
Un seul regret.... j'aimerais bien comprendre pourquoi il est si incroyable.
Philippe H.
Musicalité avant tout
A peine le montage sur Viborg pur cuivre terminé, installé sur mon DAC Hegel HD30 ça sonne déjà, naturel, extrêmement nuancé dans le jeu, très différencié dans les timbres … quelques jours après, la scène sonore est stabilisée, davantage profonde que large, le retour en arrière sur Zavfino Majestic est tout simplement impensable.
Philippe D.
Bon câble
Monté sur des prises Furutech, il vient remplacer un câble d'origine sur une barrette Furutech, ça marche mieux. Fort diamètre attention aux prises.
Patrick S.
Impressionnant
Ce câble est une révélation, car il n’a pas démérité en le comparant à des ténors de la catégorie. Associé à des Viborg plaquées or/argent il a réussi à détrôner mon câble fétiche à plus de 1000€ dont je tairais le nom.
Après une bonne cinquantaine d’heures de chauffe, il est d’une cohérence et d’un équilibre à faire pâlir, voire trembler les grandes marques prestigieuses. Les timbres sont de toutes beautés avec un médium émouvant.
La dynamique frôle la perfection avec un son riche et maîtrisé. Quant aux aiguës, ils filent sans s’arrêter dans un soyeux envoûtant.
Bref c’est que du bonheur
Merci audiophonics pour ces pépites au RQP imbattable
Matos : ampli et cd Roksan K2, HP Focal Chorus V 826 re câblée athom mini
Mogami w3103 pour les HP
ET Mogami w3082( c’est une tuerie) pour la liaison cd/ampli.
 (5)
Patrice S.
Quelle surprise !!!
Alors, marche ou marche pas les cables secteurs ? Il y a tant d'avis opposés sur le sujet que je tente régulièrement l'expérience avec du matériel à prix raisonnable.
J'ai donc acheté 2m de ce CS-361B et j'ai équipé deux câbles de 1m avec des connecteurs de la même marque (PS et PI 24).
Je possède à ce jour 1 cable CS-331B, 1 CS-321B et 2 CS-361B, branchés sur une barrette secteur Wireworld Matrix II. Mon matériel audio est tout ATOLL (série des 100) et enceintes Récital Audio modèle Illumine (au passage excellentes enceintes au RPQ très très bon).
EH BIEN QUOI QU'ON EN DISE ÇA MARCHE SUR MON SYSTÈME !!! Mais en fonction des câbles et leur emplacement sur la barette c'est parfois si subtile que je pense que placebo n'est pas loin. En revanche le CS-361B en alimentation de la barrette a eu un effet foudroyant...d'un coup et pas au bout de 40h00, le son s'est libéré, il s'est éclairci, les notes se détachent nettement et finissent lentement, la scène sonore a gagné en profondeur, dans les orchestre les groupes d'instruments sont plus lisibles avec un meilleur positionnement dans l'espace, il est précis, mais attention aux mauvais enregistrements, il laisse tout passer dans mon cas. Ah oui, les masses ont bien évidemment étaient contrôlées avant branchement.
J'ai essayé de nombreuses combinaisons avec mes câbles mais la plus flagrante, et de loint, est de positionner le CS-CS-361B en entrée de la barrette. A ce jour mon système fonctionne avec CS-361B entrée barette et ampli, CS-321B sur le streamer et le CD passera en CS-321B car de mon système j'élimine le CS-331B pas assez dynamique et limitant les médiums et aigus dans mon cas. JE SUIS RAVI, le résultat sonore me convient et cela par des investissements progressifs et peux coûteux au regard du résultat.
Je trouve ce cable assez souple, malgré son diamètre, et pour donner une idée de l'encombrement, il faut un espace minimum de 11cm entre le mur et le meuble accueillant le matériel.
Pour finir je ne peux que conseiller ce câble en alimentation d'une barrette. Pour le prix il faut tenter l'expérience.
 (5)
Christian T.
Je ne m'y attendais pas !!
J'avais un câble secteur payé plus de 500 € qui avais reçue plusieurs récompenses etc ...et j'ai commandé un morceau de 1m de se câble ELECAUDIO CS-361B; au début pas trop convaincue de l'apport de se câble par à port à mon câble à plus de 500 €
J'ai monté se câble avec des fiches FURUTECH PIEZO Céramique FI-50
le résultat final donne un son bien meilleur que sur mon câble de référence vraiment bluffant.
Pour être sur que l'amélioration ne venait pas que des connecteur FURUTECH j'ai interchangé, le verdict est sans appelle, l'ELECAUDIO reste meilleur.
Un son largement plus naturel et réaliste je n'en reviens toujours pas pour un bout de câble payé 25€
Je suis vraiment satisfait des produits audiophonics et des choix proposé, on y gagne vraiment rapport qualité prix.
Christophe E.
Trés bon cable.
Essayé à la suite du 321b, celui-ci va plus loin sur tous les plans ! Il fait chanter mon Atoll DAC200.
Honnêtement je suis bluffé par la qualité de restitution de ce cable ! C'est un veritable up-grade de mon équipement.
Rapport qualité pour moi très bon. Je viens être convaincu par le bienfondé de l'apport qualitatif des cables d'alimentations.
Je pense que je vais équiper mes amplis avec .... à voir
Merci pour Audiophonics et son service super efficace !
 (3)
ALBERTINO GOMES A.
Merci Audiophonics
J´ai demandé un avis pour acheter un cable avec 2 metres car je voudrais conecter une barrete de secteur un peu plus loin de la place ou j´ai tout le sistéme. Je suis trés ,trés satisfait car la recommendation funcionne trés bien ,c´est un cable plus précis ,plus neutre et meloudieux que le Yarbo 7000 que ´avais avant. Maintenant la combination Yarbo 8000 sur l´ampli ,le 7000 sur le cd et l´Elecaudio sur la barrete funcionne trés, trés bien. Je veux dire ,de novo, excellent service ,livraison trés,trés rapide ,merci Audiophonics pour votre bon service
Gilles C.
Câble neutre et assez dynamique. Prévoir des connecteurs adéquat vu le gros diamètre.
Hendrik W.
Wonderful cable for pre-amp
I was a bit sceptic about the improvement this cable would make to my equipment. I have made one to my Denon AVP-A1 pre-amp and the improvement was hugh. Some very good noticeable improvements:
- Overall sound clearity.
- Sound stage in height.
- Highs are much more natural.
- Bass is not more but thightend up.
- Volume on same settind needed to be increased.
Note that this cable needs to settle for about 40 hours. After connecting and playing for about 2 hours I was worried that this was wrong cable as soundstage was 'moving around', but after settling down the above mentioned improvements were very obvious.
I also made a cable voor my Denon AVR-2313 in an other setup in different room. Also improvements here, but not as spectacular as with the AVP-A1. I only use it in 2.1 setup and the improvements here are:
- For me no need for subwoofer anymore (more and thighter bass).
- Stereo setup is sounding really 3D in good film sound recording and therefor no need for center speaker (as I was thinking about before applynig this cable).
Kind regards, Henry
 (3)
Gareth J.
Super rapport qualité-prix
Voici un cable secteur remarquable, équilibré et neutre. Peut-être le meilleur rapport qualité-prix. J'en suis ravi. Merci Elecaudio et Audiophonics.
Christophe h.
basique, mais pas mal et pas trop cher!
en fait je le connais dejà, sur mon ampli de puissance: correct, un peu pataud en fait, mais une belle energie... Là je l'ai pris pour en recuperer les conducteurs et la tresse... Fabrication a partir de bons materiaux, mais geometrie du cable quand meme tres basique... Je mets quand meme 4 etoiles, car au niveau rapport performances prix, c'est tres bien!
 (6)
Florent C.
Bienvenu chez les fous
ça y est, je fais partie des fous qui ont changé leur câble secteur et trouvé que cela changeait beaucoup de choses à leur système.
Je n'y croyais absolument pas. Comment 1m de câble 220V peut changer quoi que ce soit au son de mon système. Après avoir trop lu que cela apportait, j'ai craqué... et force est de constater que c'est bluffant, c'est même déroutant. Les voix ont plus de détail et de corps, plus de présence, les cordes trouvent une texture que je n'avais jamais entendu sur mon système. En bas du spectre, c'est aussi mieux défini, plus nuancé sans perdre à la profondeur des basses.
D'un point de vue pratique, j'ai mesuré en le recevant ce que représentait un câble de 17mm de diamètre. C'est ENORME ! Prévoir un espace important derrière le meuble car ce câble ne pliera pas.
Je recommande l'expérience. J'ai choisi des connecteurs "basiques" pour baisser la note et je ne le regrette pas.
 (7)
Geir P.
Time to wonder what a power cable can do
For my new project "Nord Hypex NC500 monoblock"
www.iqspeakers.co.uk/hypex-amps
I need to build some new power cable, last weekend we was building 4 different type for verification and test. After testing all of them this one shines. All the other one was not close to this one. Reason is.
I get more dynamic sound a lot more "Crezy I think, before I play typical with -20 to -17dB. now I use -30 to -25dB.
More details in the sound image.
The sound is warm with a grate dark room that I newer have heard before.
And the reason is a power cable!
Are I'm Crazy??????
 (7)
arnaud r.
Un excellent câble secteur.
Associé au prise shucko et IEC de la même marque, ce câble secteur a bonifié "mon installation" Hifi sur beaucoup de paramètre tel que la qualité des timbres, l'assise, la précision du message et la scène sonore. Tout est plus clair plus précis plus détouré.. C'est étonnant!
La musique a même perdu cette acidité que certains morceaux faisaient ressortir auparavant.
Je suis absolument satisfait.
Ce n'est pas pour rien qu'Audiophonics intègre ce câble secteur son ensemble secteur haut de gamme MP6.
Je le recommande chaudement pour des installations ou on a l'impression qu'il manque ce petit quelque chose.
Mon installation composée d'Atoll In 200 / Hegel HD11 / Davis Cezanne s'est transfigurée.
 (6)
