Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
ELECAUDIO FC110TS Fil de Câblage Cuivre / Argent FEP 1mm² (Noir) - avis - Il y a 2 avis.
DIMOKRITOS D.
Wisely structured wire at a great price
Great cable for the price, I use it for interconnect cables and internal wiring in devices and speakers with great results. Its structure is wise and obviously researched. Its very fine strands ensure a very large surface area on the wire equivalent to a 17mm wide ribbon type wire. Silver plating gives serious sonic advantages. The thin FEP insulation needs care because it tears relatively easily but I prefer it as is because it absorbs significantly less energy from the signal than the other options. Sonic character is very dynamic, extended, detailed and natural in tone, much better than bare OFC coper and inferior only to the much more expencive OCC coper
jean michel G.
Très bon
J'ai utilisé ce fil pour le câblage interne des enceintes bornier vers filtres aigus médiums. Un plus côté aigu plus fin et moins agressif.
