Gérard B.
Buffer Audio type YAQIN SD-CD3
Après des écoutes attentive et relaxante, pour bonifier votre source que ce soit un CD, une platine Vinyle ou un DAC Bluetooth...
Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Marco R.
THINKYA JA-310 CD
The player looks quite nice considered the price.
It connects via toslink to a pair of Klipsch "the fives" and audio...
ETI LEGATO Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Or Ø20mm - avis - Il y a 4 avis.
Alexandru Ovidiu A.
First class connectors
Used on a Furutech 762 AC cable. Very neutral, very dinamic sound. Very good connection points and very clever and efficient cable holding system. Used on Amplifier.
Michael N.
Superb mechanical and audible quality
Solid and stable mechanical construction. Everything fits here, easy but efficient. Hugh difference in regard to "gold plated" compared to other connectors!
Tonal very fine, well balanced and detailed - best connectors I ever bought!
Jacques B.
Superbe produit
Qualité de fabrication irréprochable permettant une haute qualité de contact et d'assemblage avec le câble secteur. Transparence et qualité de timbrage superbe par une transparence hors norme. A mon sens, plus neutre que les connectiques Furutech, sans nier leurs qualités également. Superbe mariage avec le secteur DPS 4.1 Furutech avec un apport concret dès la mise sous tension. Bravo !!
Grzegorz B.
One of the best power connector
I tried almost all power connectors for better audio equipment, the are almost the best. You can mount with or without crimp sleeve (better and safer with), in Schuko up to 6mm in IEC up to 4mm. In can is enough space to prepare cable comfortable (much better than Furutech 46/48/50 and cable holder is better than in Furutech, because don't damage cable like jaws in Furutech. Screws that merge both halves are screwed in aluminum, not like Furutech in thin plastic.
 (5)
Le connecteur Schuko ETI Legato profite d'une construction haut de gamme basée sur l'utilisation de composants de grande...
