Jean-Christophe B.
Bon câble, mais attention…
Voilà j’ai reçu cette paire de câbles’
Ceux ci m’ont l’air très solides Mais il y a deux petits soucis qui méritent d’être...
Jean Paul T.
Très bon
Très bon pour comparer à l'écoute deux amplis ou deux paires d'enceintes. basculement très simple par télécommande,...
Bruno T.
FURUTECH FP-209-10 (R) Fourches Pur cuivre Plaqué Rhodium Ø4mm (Set x10) - avis - Il y a 2 avis.
Rene C.
Best buy
The fork is very solid, you can´t climp it to a cable with normal tongs !
You have to have access to and use a screw- device - wrench.
Only the final finish can be done with strong tongs !
Otherwise it is fine product, that sounds great !
Grzegorz B.
Very good quality product
I use them after crimp on cables for mount cables in power plug with rodium coatings. You have to use carefully, because the FP-209 are long and you can have about 0,5 cm of free cable (with inner isolation) to mount them in Furutech IEC power plugs. With longer free cable you can't holding whole cable in plug jaws. There limitation is only for IEC, for Schuko you have more space in power plug.
 (4)
