Lennart H.
Eric H.
Bonne qualité
Bon rapport qualité prix : fait le job !
Eric H.
Excellent câble
Très bon câble sur tout le spectre
Amène de la clarté et pleins de détails deviennent plus apparents.
Je recommande son achat
HA INFO DA1 DAC Amplificateur Casque 24Bit/192khz - TE7022 - avis - Il y a 2 avis.
Joaquin T.
Chauffe beaucoup trop
Fonctionne normalement mais la température de l'appareil est vraiment exessive.
Anon
HA INFO DA1 review
Gets very hot. Not for non-stop operation. Caps are 85 degrees and it gets above that inside the case after half an hour or so. Very strange power supply arrangement. DC feed is 18 volts and a floating earth is obtained by usage of a power amp (TDA2030) providing a floating earth on its output. This chip is on a rather large cooler but still gets extremely hot.
Sound quality: There is a distinct ringing in the high mid / low treble area. Otherwise ok. But the ringing "s"-sounds, etc, are exhausting.
