Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
HIFIMAN HE400SE Casque Ouvert Planar Magnetic 25 Ohm 91dB 20Hz-20kHz - avis - Il y a 8 avis.
Eemeli T.
A very good value for the money
I am confident that HE400SE is the best sounding planar at sub-140€ price category and beats many way more expensive products. In fact I was totally amazed how good they sound and feel out of the box. With a tiny bit of EQ these are superb.
Lack of distortion makes HE400SE a delight to listen to. The cups are big as kettles and the cushions soft making these quite comfortable to wear, albeit they're a bit on the heavy side. Another good thing is that unlike many headphones, these can be adjusted for small head aswell. The supplied cord is soft and flexible but not very long.
All in all HE400SE delivers a lot with a little money.
Eemeli T.
A bargain
Excellent quality-price ratio. Little thin in bass but easy to EQ.
Pedro V.
Great audiophile headphone - with some caveats
These entry level Hifiman headphone sound excellent with acoustic music, jazz, classical provided you use them with a proper amplifier - smartphone or tablet will not cut it.
It sounds a bit "edgy" with an Adioqiuest DragonFly 1.5 but sound great with a Schiit Vali 2++ and Audiphonics RaspiDAC streamer, beating my Massdrop/Sennheiser HD 58x as the best "budget audiophile" headphone.
The cable could be a bit longer and would prefer it was terminated in a straight rather than an angled jack (in particular because it is much better suited for stationary listening).
Elom G.
Très bon casque pour un usage domestique
Acheté en remplacement de mes akg studio k240, le son est plus doux et plus équilibré (basses, medium et aigus).
Fonctionne correctement avec la sortie casque de mon smartphone, mais c'est encore mieux avec un petit ampli casque (pour moi, le earstudio de Radson).
Attention : c'est un casque ouvert, donc plutôt pour un usage domestique, dans le métro ou dans la rue, le bruit ambiant rend l'écoute assez décevante voire désagréable.
Elom G.
Très bon casque Hifi, bien équilibré
Encore en rodage mais déjà un très bon son par rapport à mon précédent casque AKG k240 sont les aigus étaient criards et les basses en retrait.
Le son du hifiman est bien équilibré : les aigus doux, le médium chaleureux et les basses bien présentes sans écraser le reste du spectre sonore.
Après avoir testé différentes marques, ce hifiman me donne pleinement satisfaction.
Seul point de vigilance, la sortie du smartphone n'est pas suffisante, il lui faut un sac ampli casque extérieur pour bien l'alimenter, un earstudio dans mon cas.
Autre point : votre musique est assez audible de l'extérieur vu que c'est un casque ouvert.
Au delà de ces deux points, c'est un super casque, à recommander.
leny l.
Tout parfait
Très fidèle aux critiques que j'ai pu lire ou voir, c'est en effet un très bon casque pour son prix. Je m'attendais à recevoir le fameux "très mauvais" câble qui va avec, et non. Bonne surprise il est maintenant livré avec un câble de relativement bonne facture, la marque à donc écouté les critique et apporté cette amélioration.
Livraison ultra rapide dans mon cas, merci audiophonics.
Rien à redire
stephane d.
une revelation
c'est mon 1er casque planar et je dois avouer que c'est plutot pas mal à condition de l'associer à du bon materiel pour en tirer pleinement profit, utilisé avec un dap hiby r6 et ampli dac hidizs DH80S avec cable usb c fourni avec, et des fichiers flac, hi-res et dsd, je redecouvre un plaisir encore meilleur auparavant même mon fidelio X3 qui est pourtant très bien mais un ton en dessous je pense, mention speciale pour le dac hidizs qui s'associe bien à ce casque et ce sur les bons conseils audiophonics chez qui j'ai acheté ce casque, merci à eux et un conseil à ce prix là vous ne regretterez pas.
eric l.
EXCELLENT
Son clair et bien detaille,les aigus son cristallins,les graves present mais pa imposant,medium parfait.Trés bon casque
HIFIMAN propose avec son HE400SE un casque ouvert Planar Magnetic de grande qualité et à prix contenu. Utilisant la...
