Pierre H.
4N ou 6N
Bonjour
Tous les avis sur ce câble donnent vraiment envie d'acheter de câble mais ils parlent d'une référence 6N...
Didier C.
Etonnante petite boite !
J'hésitais à acheter une alimentation linéaire pour remplacer celle d'origine de ma box Orange, mais j'ai voulu...
Didier C.
Efficace
Utilisé entre une livebox Orange et mon streamer Lumin T2, il fait son petit effet. On ressent une progression de la netteté...
IAN CANADA FIFOPI Q2 ULTIMATE Module Reclocker FIFO PCM 32bit 768kHz DSD1024 DoP - avis - Il y a 2 avis.
Charles M.
Great idea but no support
I purchased this after reading Ian's posts demonstrating that it worked with Buffalo III DAC. I have not been able to get these two boards to work together. After reaching out for support over a period of weeks there have been some replies but none simply describing how to configure and connect these two devices. Great idea but of no use without support.
Thomas v.
Perfect way to transport your audio onto your dac!
This module is the absolute best way to transfer your audio from your Raspberry Pi (or other single board computer). This modules enables you to upgrade the very important clocks (for instance with ACCULUSION clocks). The module is extendable with other products from Ian Canada or can transpass the audio onto your dac via I2S.
 (3)
Le FiFoPi Ultimate de Ian Canada a été conçu afin de réduire considérablement le jitter du...
