Patrick W.
Très bon produit et envoi express
Deuxième achat de ces tubes en même temps qu'un tube redresseur 5U4GB, très bons produits et surtout envoi très rapide et...
Leszek W.
Solid build quality and a significant improvement in the sound of the powered device. I highly recommend it, especially if you...
Leszek W.
IR TSOP32338 Récepteur Infrarouge Directivité 45° 38Khz - avis - Il y a 2 avis.
Bengt N.
Working well
This remote receiver is working well in the volume control/input selector PCB after a small modification. Instead of soldering it straight with pins 1-2-3, it should be mounted 1-3-2., two of the leads swapped. After this it is fine!
And you should know that it is not working without the display attached...
Robert V.
Top
Comme décrit .
