Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
LG ELECTRONICS NR18650 Accumulateur Lithium-Ion 18650 3.6V 3350mAh Rechargeable - avis - Il y a 1 avis.
Cernat G.
Great capacity.
The capacity is very nice, but this is based on older technology and you can not draw lots of current continuously.
On my builds, when the battery gets to about 25% I need to turn the volume down. Continuing to play at or near max level will cause the BCPB3 to enter protection mode. It stops any current and I need to connect it to the charger for 1 second or so to bring it back On.
This is most likely due to the battery dropping voltage too much under higher load, causing the undervoltage protection to kick in, even though, you are actually well above 3v for each cell.
Cette batterie au Lithium-Ion type 18650 de chez LG Electronics est idéale pour fournir à des appareils de tensions et...
