Very nice device, but no standby What I like: 1. Overall the build quality is very good, the PCB is sturdy, seems to be populated with quality components. 2. Sort of nice surprise: if wired properly, one can control 5(+1) stereo inputs ;)
There are is one thing which I don't like: there is no Standby functionality.
Pay attention when wiring the rotary control. If plugged in incorrectly, the input selection will always go only one way. If wired correctly, turning left will decrease the input number, turning right will increase it. When it gets to the end, it starts from the opposite end. One question: what is the MON button supposed to do? Press once, the currently selected channel LED blinks, press 2 times, all the LEDs light up for a second.
Istvan N.
Not bad, could've been better What I like: 1. Overall the build quality is very good, the PCB is sturdy, seems to be populated with quality components. 2. Sort of nice surprise: if wired properly, one can control 5+1 stereo inputs ;)
There are two things which I don't like: 1. there is no Standby functionality 2. The input selector goes only one way, no matter which direction the rotary is turned. I would've expected that if it's turned to the left, the inputs are switched by decreasing order, and if turned to right, the other way around...
jean paul g.
JLG produit excellent je l'ai associé à mon ampli tubes pour commander mes entrées USB, optique, etc, le tout enfermé dans un boitier métallique non relié aux masses de l'électronique .pas de bruit de fond .....super
Elsa A.
Bon mais incomplet... Bonne qualité de signal (la telco est opérante à plus de 8 m )et de commutation, dommage que seule la LED du canal1 fonctionne, les autres restent éteints... la façade du pot est à la masse, je l'ai isolée du boitier pour éviter une boucle de masse, à chacun de voir...
Philippe H.
Attention les résistances R17 et R18 sont absentes, n'oubliez pas de les commander si vous ne souhaiter pas la remise à zéro du volume à l'allumage et à chaque changement de voie.
eden D.
Les valeurs données pour R17 et R18 sont fausses :
R17=10R --_ pas de reset du volume à chaque changement de canal! R18=10R --_ pas de reset du volume à la mise sous tension!
Nécessiterait des liaisons blindées pour les parties modulation!
Frederic g.
Super rapport qualité. Idéal pour ce monter un petit pré ampli sans se soucier de la fonction sélection de source et commande de volume.
Vous devez vous identifier pour poster un avis.
Le texte de votre avis est requis.
Vous devez patienter 30 secondes avant de poster un nouvel avis.
Texte de l'avis invalide.
Une erreur est survenue. Essayez ultèrieurement.
Vous avez déjà posté un avis pour cette commande.
Le code de sécurité est incorrect. Merci de réessayer.
