FRANK D.
FRANK D.
Impressionnant.
Solid core has always been a favourite of mine, be that for LS cable, interconnect or as a hook-up wire.
It simple sounds...
Jukka M.
Very good banana plug
Easy to use, has two screws, very good contact with wire, good contact into socket. This is now my favorite banana plug!
LOXJIE D60 DAC Amplificateur Casque ES9039MSPRO Bluetooth 5.1 32bit 768kHz DSD512 MQA-CD Noir - avis - Il y a 1 avis.
Andrzej B.
Loxjie D60 - excellent DAC/Headphone Amp
Very transparent and neutrally sounding DAC. I use it with headphones Hi-Fi Man Sundara Closed Back edition via balanced connection and as a source I use WiiM Mini connected via Optical link. I am very satisfied with the sound.
As regards funcionality it has all important digital inputs including I2S and outputs (including headphone balanced XLR) and bluetooth connection with high quality codecs (LDAC and Aptx HD). The only drawback I noticed is very poor stability of bluetooth connection when using highest bit rate of LDAC codec (900 kbs). The are frequent drop outs so it needs to be switched to lower bit rate (606 kbs) or use different audio codec like AptX which works fine. Everything else works perfectly.
It is also very good for the price. I can truly recommend it.
The ordering, payment and delivery process at Audiophonics was perfect. I was really satisfied.
Avec son DAC / amplificateur casque D60, la marque Loxjie propose un appareil moderne et performant, conçu avec soin et...
