Patrick W.
Très bon produit et envoi express
Deuxième achat de ces tubes en même temps qu'un tube redresseur 5U4GB, très bons produits et surtout envoi très rapide et...
Leszek W.
Solid build quality and a significant improvement in the sound of the powered device. I highly recommend it, especially if you...
Leszek W.
LT3045 Régulateur de Tension Linéaire 5V - avis - Il y a 1 avis.
Johan G.
Johan
These regs have a favourable price level but there is a distinct lower level quality on the boards compared to ldovr variants. The soldering is quite sloppy with some of the regulators having an excess of solder on the connection pins.
The component values differ from that of the TI manual recommendation. The for noise critical Cset is 20x (0,47uF) to small so the advertised noise figures here cant actually be met. So these are not 0,8uV. The 2 other caps is however 10x bigger (47uF) than the smallest value recommended. Did someone mix up the values... Go figure...
These would be very nice if Cset vas altered to 10uF and the soldering and cleanliness of the product could be improved.
Le régulateur de tension linéaire LT3045 offre d'excellentes performances et est idéal dans des...
