Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
MINIDSP FLEX HT Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS HDMI ARC eARC - avis - Il y a 1 avis.
Szilard S.
Flex HT the audiophile nirvana!
I bought it on December 18, 2024. It arrived in Hungary very quickly. I replaced a Lexicon MV-5 processor. The bass is much more restrained, not so fluid and expansive. The active switching also works very well in it, I use LW-R 24db/octave filters. The crossover frequencies are 100Hz/4KHz. I don't use Parametric EQ for now, maybe when I buy the Umik-1 measurement microphone. It would be nice to buy a Dirac live license for it, but for now it's very expensive for me, almost the price of the device. There are power stages for each speaker, for each speaker, I use these now, all class D: AUDIOPHONICS MPA-S125NC ; Douk Audio TPA3116 ; Wondom TPA3255. I'm going to order these two power amps from Audiophonics now: O-NOORUS D1 Class D Amplifier TPA3255 PFFB. My dream is to get one of these power amps: AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels NCore NC252MP. This MiniDSP Flex is a real big gun, a game changer, the DAC in it is also very good, this is also confirmed very well by the Audio Science Review. I recommend it to everyone who would like to build a truly audiophile system with active switching. I use 2x3 way speakers with it, each in pairs: Dayton Audio PT2C-8 Planar Tweeter ; Tang Band_W5-2143 Midrange; SICA 12 PF 3 Sub. The fronts are open baffle, and the subs are closed! Thank you Audiophonics!
Le miniDSP Flex HT est un processeur de la gamme des processeurs audio avancés miniDSP Flex. Cet appareil est...
