Dominique R.
Nette amélioration du son
Bonjour, j'ai acheté 2 câbles Pangea secteur, car ils étaient en promo et que je souhaitais depuis longtemps avoir des...
Daniel D.
contre pointe sous enceinte
Installés sous des grosses THIEL CS 3.7 munies de pointes avec en plus une petite plaque de liège de 1cm très souple posée sous...
Christophe C.
Excellent en tous points
Acheté suite aux bonnes critiques et je ne suis pas déçu, il remplace très avantageusement un audioquest G2. Ma config est...
Module Alimentation A-19 2x3-20V LT1083 - avis - Il y a 6 avis.
Zdenek B.
Very good power supply. Adjustment is stable. Almost no heat dissipation with the right transformer.
Michel a.
fine power module
the module perfectly meets my expectations, is easy to set up and therefore keeps exactly the value, even under load.
despite the corona problems, I quickly had the power module at home.
perfect!
Michalis B.
Great PSU
It works perfect!
This unit replace an old psu with the classic DC regulators LM317 / LM337.
Somebody here at reviews ask if can works as symmetrical + -v power supply. The answer is absolutely YES!
Works for me exactly as i was need. With AC 10V in every side, i have exactly + - 7.5 V OUTPUT!
The only thing you MUST do is to put a jumper from - to + exactly in the middle of the board (at output side), and grounding this point!
Also, no ripple, and imidiatly you can listen your difference from your old power supply!
Thank you Audiophonics for your products!
 (3)
Patrick d.
Great well build product for the money
Great well build product for the money. As far as I was able to measure ripple free output.
Filippo T.
Good PSU
I checked the PSU at 18V output and results are very good, undetectable ripple and stable voltage.
Yannick M.
bonjour,
je voulais savoir si cette alimentation est bien symétrique , + et - 3 à 20V
merci
Ce module d'alimentation prend en entrée une tension comprise entre 5V et 25V AC pour sortir une tension de ±3V...
