Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
Module Récepteur Bluetooth 5.0 QCC5125 LDAC aptX HD aptX Adaptive vers I2S - avis - Il y a 2 avis.
Martin M.
USB Communication
Search for SJR-BTM525, this is the name of the blue module and find module pinout
To enable USB communication you need to solder "USB_DP" and "USB_DM" to your preferred connector and you must solder/connect "VCHG" to your power voltage, without this the USB is disabled.
I connected "VCHG" to +5V currently working but not sure, maybe you should use +3.3V
PLEASE REFER TO CHIP DATASHEET (not module) TO AVOID ANY DAMAGE!!!
No-one takes responsibility for how you modded this module ;)
Martin M.
Defaualt code is "0123"
lot of product here missing some useful description
Ce module de réception Bluetooth 5.0 est équipé de la nouvelle puce Qualcomm QCC5125. Celle-ci supporte les codecs...
