Markus W.
Good quality
Patrick v.
Magnifiques !
Tom K.
Module Sélecteur de Source CS8416 2 Entrées SPDIF vers 1 Sortie I2S - avis - Il y a 1 avis.
Jakub P.
Not for Raspberry Pi
The quality of the product is good, that`s why I give it 5 stars, but unfortunatelly it doesn`t work with Raspberry Pi/Audiophonics ES9038Q2M. If you want to have an optical or coaxial S/PDIF input in your DIY streamer, then just buy an optical/coaxial spdif socket and connect it to spdif + ground pins (+5V for optical socket) on Audiophonics DAC. You must also take into account the necessity of adding two capacitors to avoid "reloading" effect (lags in audio via optical spdif input).
Ce module est un module d'entrée disposant d'une entrée Coaxial et d'une entrée Optique. Il se base sur un récepteur audio numérique...
