Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
OYAIDE DB-510 Câble Numérique Coaxial BNC 75 Ohm Argent 1m (Unité) - avis - Il y a 1 avis.
Pino M.
excellent cable!!
I own a Chord digital system that requires BNC SPDIF cables to express it's best: this cable makes the system to sound really well, better than any other I tried, great value for it's cost.
