Jam M.
6V6GT Electro Harmonics
Les tubes sont bien appairés. Les caractéristiques sont confromes.
Seul défaut: construction du tube non parfaite:...
Patrick V.
to much money for what you get
I received the case with one heatsink dented. So if this unit was intended for a client it was already useless. If you want a...
Please contact our customer service team via the forms on the website; the damaged part will be replaced.
Philippe T.
Excellent
Voilà il est arrivé .. il se rôde .. les premières impressions sont excellentes.. une très belle séparation des canaux .. un...
Prolongateur Extension pour AOP DIP8 Cuivre OCC Argent 30mm - avis - Il y a 5 avis.
Mikael E.
Very fragile, broke immediately.
As soon as I began to bend the wires, one of them broke off and ruined the extender. The extender I received looks nothing like the picture shown here. It has black protectors in both ends, making it even more difficult to bend the wires correctly. This was my first attempt of rolling op-amps and I am not sure I am going to to do it again.
Hello,
We have never had a problem with this accessory.
In the absolute it is not really designed to be bent or twisted in any ways.
Joris J.
Quality product. Great value.
Good, sturdy, quality wiring.
I used it to solder and seperate little circuit around the sparkos ss3602, powered by seperate power supply (seperate from digital part of the DAC.). Spectacular improvement over the sparkos directly dropped in.
loris c.
adaptateur
fait ce qu'il faut faire m'a permis de monter le bourson v6 vif dans un petit espace (sans lui je n'aurais pas pu le faire) juste faire attention quand il faut se pencher.pour le reste excellent
Marjan v.
Big improvement
Well made.no Short on signals.
Stephane I.
prolongateur dip 8
Fragile et cher ,ne peut pas être courbé,sinon il casse ,s' utilise seulement droit ,tenir compte de la hauteur du coffret.
Bonjour,
Le prolongateur peut être courbé, mais de façon délicate et avec précaution.
Cette extension pour AOP au format DIP8 s'avérera particulièrement pratique pour effectuer des montages d'AOP sur...
