Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
QULOOS MELOKIN DA9.1 DAC ES9038PRO 32bit / 384kHz DSD512 I2S - avis - Il y a 1 avis.
Miguel M.
Lest be brief, the Melokin DA9.1 sounds very good, currently tested with an unmodded AKG701, it does have plenty of connection options and the option, if you are so inclined, to add XLR,
The not so good and the reason why it loses one star are some little, but important, annoyances the unit have. To note:
-the input selection are labeled with abbreviatures, instead of the actual names, and those are misprinted in the manual.
- For some baffling reason Quloos opted to use several screw types, Torx, Van Allen, Phillips... makes dissasemly a bit of a PITA
Quloos propose avec son DAC Melokin DA9.1 un excellent DAC intégrant des composants de grande qualité, avec notamment un...
