Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
SMSL PO100AK Interface USB XMOS XU316 DAC AK4493S 32bit 768kHz DSD512 MQA - avis - Il y a 1 avis.
Andreas P.
As a dac
The first impression is that it has a serious problem with the stereo cross talk;huge difference between left and right and generally not the warm sound you would expect from an asynchronus usb dac.Also do not use the included cable as it makes the problem worst.
Le SMSL PO100AK se présente comme une interface USB avec DAC intégré extrêmement performante et...
