Rafa P.
Great for inside speaker wiring
Awesome cable. I am also very satisfied with the service from Audiophonics.
Rafa P.
Great cable
I am very satisfied with this cable. The service from Audiophonics has been fantastic.
Dominique R.
Nette amélioration du son
Bonjour, j'ai acheté 2 câbles Pangea secteur, car ils étaient en promo et que je souhaitais depuis longtemps avoir des...
SOMMERCABLE MERCATOR CAT7 Câble Ethernet OFC 4x2x0,25mm² Ø7.6mm - avis - Il y a 4 avis.
Adam S.
works very well
it is identical with the viablue solid core rj45 cable
are 99,9% sure its the same cable viablue sells for almost 15 eur
the sound from tidal is the same with both cables
very good top performance
Laurent F.
excellent
rapport qualité/prix excellent
fil interne rigide
a permis de transferrer la box tv ,avec 15ml de ce cable , de la box internet
GONZALEZ POZO J.
Dinero recompensa de fidelidad no utilizada
Yo hice este pedido pero lo anule por falta de stock del producto. Utilice el dinero de la recompensa de fidelidad pero en realidad al anular el pedido no lo utilicé. Ahora voy a comprar y no veo este dinero. Por favor me gustaría recuperarlo para utilizarlo en la siguiente compra. Gracias
Manfred W.
Good industry standard improved "sound"
I have connected this cable with the Telegärtner Cat6 connectors. So for less than 25€ you get a high quality Ethernet cable. Covered it with a black sleeve for optics only. Compared to a CAT8 certified finished cable, which I used before, there is a noticeable improvement.
I use the Ethernet cable after a fibre/optic to Ethernet converted to connect to my Allo USBridge Signature streamer.
Only downside of this cable is, it is a bit stiff.
Compared to the Viablue 7S Ethernet cable, which has basically the same specs (23AWG solid core conductors, and they are not silver coated as in the description from Audiophonics!!) the Viablue cable is 5x the price of this Sommercable. The performance of the Viablue EP-7S is slightly better and the Viable is more flexible.
For longer runs of cables, I would go with the Sommercable, for shorter runs my choice is the Viablue EP-7S.
Both are really worse the effort to replace any standard CAT cable in your system.
