Igor C.
olivier r.
Très bon mais pas neutre
FRANK D.
TINYSINE AUDIO-B PLUS Module Récepteur Bluetooth 4.2 aptX SMA - avis - Il y a 1 avis.
Steffen K.
Is working fine, but not the advertised chip
The module seems to work fine, but the description is not correct. It says it has the CSRA64215 Bluetooth 4.2 chip, and the one I received had the QCC3008 Bluetooth 5.0 chip on it.
Si vous souhaitez fabriquer un amplificateur Bluetooth simplement et pouvoir streamer votre musique depuis votre smartphone, alors le module de...
