Lionel B.
Excellent
Ampli livré 2 semaines après la commande, comme annoncé. Très bon matériel. Le boitier est bien fini et compact. L'ampli...
Bruno L.
Superbes!
A mon avis et dans mon cas d’usage il sont excellents et supérieurs aux MUNDORF SUPREME SILVERGOLD OIL que j’utilisai jusqu’à...
Zean V.
Bon produit - logistique à améliorer
Bon produit pour la calibration avec REW.
Réception après 8 jours (lent quand on à l'habitude d'Amazon)
Le suivi...
TOPPING A50 Amplificateur Casque Symétrique Argent - avis - Il y a 5 avis.
Angelo C.
Un ottimo amplificatore per cuffie
Piccolo, elegante, solido e soprattutto con un bel suono. Ha una potenza notevole, capace di far suonare con facilità e con piacere anche delle cuffie ad alta impedenza come le mie Sennheiser HD6XX
Martin B.
Satisfied
this is my first headphone amp but im very satisfied, nice build quality, i paired it with Beyerdynamic DT 880 Edition 250 Ohm and it has plenty of power to spare, based on sound source its really loud at 11 - 12 oclock on high gain
btw ordered from Slovakia at night from Sunday to Monday and it was delivered on Friday that week and it was carefully packed
BERND M.
Pour ce prix imbattable
5 étoiles: qualité de fabrication exceptionelle, son absolument neutre et linéaire, aucune distorsion même à pleine puissance, beaucoup de puissance
Helmut H.
I also like that Amp..
.. but I'm only a listener, it is my second Headphone-Amp. For me it sounds nice and can drive a Sennheiser HD650 at +9dB loud enough for my ears.
I can't say anything more than the reviewer before, it's all I perceive myself.
The ordering process from Germany was very agreeable. I had one RMA, but it was a problem with the source I connected, not the Amp itself. The RMA was really painless. The concerns ordering a product outside my country are discarded. Thanks for that nice and gentle process!
Kristijan K.
Versatile headphone amp
I am using this connected to the Topping D50s DAC. It drives my AKG K712 and Sennheiser HD headphones. It can drive them both at the same time which I especially like because now both my wife and I can listen to the music at the same time :-) or I can switch the headphones for different genres. And it sounds fair enough good. Clean, no hissing or buzzing, not warm sounding, not cold sounding, the bass is good, feels like it has a tons of power, around 10-11 O'clock on high gain sounds like you are at some live concert. I also like the way it controls it's line out so when you turn it on it disconnects the line out (to my amp+speakers). The relays operate quietly and quickly. The volume knob is smooth. The device feels robust and really nice built. Tried also some other opamps but eventually returned to the original LM49720. So here is a first con: there is simply no place for some custom built opamps on adapters, only for regular size DIP8 chips. Keep this in mind if you want to give a go to some opamp rolling. The only real big thing I could image that would make this device just perfect would probably be a remote control as the volume is already digitized. But, well, for the price, it already has many qualities and features. And perhaps the biggest and serious con is a power button that serves as a power button on long press and as a gain switch on short press. So the one has to be extra careful when operate this button and listening at low gain because a short click will switch the output power to high gain.
Le Topping A50 se présente comme amplificateur casque sédentaire efficace et abordable. Sa conception soignée en...
