Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
TOPPING D70 DAC Symétrique 2x AK4497 XMOS XU208 I2S 32bit 768kHz DSD512 Noir - avis - Il y a 11 avis.
Dante M.
ottimo..
dac veramente bensuonante.. dettaglio e calore insieme ha un rapporto qualita' prezzo eccezionale. si puo' paragonare a dac da diverse migliaia di euro. un prodotto hiend.. sono soddisfattissimo
Gianni D.
Ottimo Prodotto
Il Prodotto è ottimo! La componentistica è di livello alto, il suono è molto neutro. A me ha soddisfatto appieno!
Kristijan K.
Almost perfect
This is my first external DAC. I bought it to replace the HT Omega Claro Halo XT and Asus Xonar ST PCI sound cards (both upgraded with AD797BRZ and BBOPA627AU opamps). The D70 technically works correctly and very nice. Turns on with the computer (USB) or TV (optical), shuts down a minute after shutting down the computer or TV (you can actually disable this), runs cool, transition between tracks with different frequencies/bitrate/format is completely flawless and silent (Foobar2000), quiet and fast relays, it has nice display that doesn't bother in the dark at all. Feels robust as if made to last. The Topping USB driver also works good for now. It shows that this is a dac version 1.04. The only thing related to the driver and worth to mention is that if you want to upsample/convert PCM to DSD, DO NOT convert to DSDxx/48Khz format or you risk some serious damage to your gear and your hearing.
Seriously. Lot of noise and crackling will be generated and pass through the driver. So be warned! I guess the D70 obviously do not support DSDxx/48, only DSDxx/44. At least not using Foobar2000 with SACD/DSD processor or ASIO Proxy plugins (various versions). Anyway, after some serious blind tests with various PCM files (natively and converted to DSD), I am definitely sure that PCM actually sounds best if played natively.
And now something (subjective) about the sound of this dac. I am using it connected via the little Chinese tube preamp (similar to FX-Audio Tube-03) that uses a pair of Voskhod 6J1P-EV tubes and a single dual NE5532 opamp on the board.
The preamp is connected to the Fase Performance 3.5 integrated amp which serves a pair of Dali Zensor 5 speakers + SVS SB-1000 sub. The sound of my previous setup including my sound cards is really tube like. Warm, soft, spacious, with very nice sonic controlled bass, everything floats, pretty exciting sound you can listen for hours. As I can see from the D70 board pics, there are three L49720NA opamps on the output soldered. One for the RCA path and two for the balanced output paths. Unfortunately they are not on sockets so not interchangeable easily without soldering and warranty void.
I am not really a fan of these opamps due to their very analytical and somewhat dry sound with a low emphasis on the bass (my experiences with these opamps and my sound cards).
So I was wandering if putting the D70 into my gear chain will produce some unpleasantly surprise. And an unpleasant surprise happened :-( The sound was pretty much what I thought it could be using 49720NA on the output stage. The magic collapsed. Yes, there were some new qualities such as more details and better highs that this dac provided compared to the sound cards, but velvet sonic warm heaven on the Earth tube bass has gone and the stage depth narrowed. Instead there was a dry and thumpy unexciting bass. A real disappointment and I was allready preparing in my head it's boxes to send it back on the day one. Because changing the RCA output opamp to something much better was not the option, got the idea to change the opamp (NE5532) in my tube preamp to something from the sound cards and to hope that maybe, but just maybe the magic could somehow return.
Believe me or not, when I changed the NE5532 in my little tube preamp to the BBOPA627AU, the magic came back over the big door. Seriously. The magic of all that warm velvet tube like soul touching bass sound came back. But this time with noticeably better vocals and highs. This is something BBOPA627AU obviously do and it is a real shame the D70 doesn't have easily replaceable opamps. So, there is a light appeared at the end of the tunnel. Finally no more obsolete PCI slots and outdated sound cards. This dac actually gives a lot, it just needs to be paired with the right equipment that can harness the potential. As soon as the warranty is over, I will definitely modify it's opamps.
Gérard G.
super
l'entrée USB n'est pas terrible,mais avec une interface Mutec (USB vers AES),ça devient franchement imbattable,avec,contrairement à un avis précédent,des graves extrêmement présents et percutants.Peut-être une dynamique demandant plus de temps pour s'installer?
Auralic Aries Mini-mutec-Topping D70-Hattor intégré-Audio Physic Scorpio II
Marc B.
Manque de punch
J'ai acheté ce dac pour peut-être remplacer mon Gustard A20H, qui possède également deux puces AKM AK4497.
Le Topping D70 est légèrement moins brouillon, avec une meilleure séparation des instruments, en revanche le Gustard est plus dynamique, la scène sonore est un peu plus large, et est bien plus agréable à écouter. A noter aussi que sur le D70, les basses sont assez peu présentes, j'ai trouvé ça assez étrange, peut-être qu'il aurait fallu plus d'heures de rodage ? (Bien que j'ai un peu de mal à croire au rodage pour les dacs).
Pour ces raisons-là j'ai renvoyé le Topping.
Lars Øystein G.
WOW!
Have tried many dac,s including Naim and Arcam D33.
Topping D70 is absolutely the best!
RODOLPHE C.
D70
Bonjour il vient en remplacement d'un moon 300 D, en position DAC (trés facile à faire passage de préamp à DAC et expliqué dans la brochure traduite audiophonic) je suis vraiment conquis relié à un streamer Ambre Metrum avec AES et en RCA à un préampli passif Light speed Atténuator et 2 blocs jadis JA 30
Mauro a.
è un prodotto eccellente che esibisce un suono materico e denso di informazioni ma mai stridente. Da apprezzare anche la altissima qualità del ricevitore spdif attualmente al vertice della produzione disponibile. Il suono attraverso la spdif appare ancora più morbido dello stesso programma trattato dalla usb . direi meno distorsione apparente e suono più " analogico ".
Gregory n.
Une tuerie
Ecoute très naturelle, tout le registre est la basse medium aigu et quelle profondeur, ecoute 3D
Fonctionne avec shanling dr 2.1 sortie coax mode pur dac surl le d70 ampli pass aleph 2 classe A enceinte elac bs312 que du bonheur
Vos largement sont prix.
Mikhail M.
re
Pour passer en mode DAC j'ai envoyé un mail chez topping, et voila leur réponse :
"When you shut off the power, press the SEL button, and then turn on the power, you will go into the system setting, choose the mode DAC, then you can use D70 as a native DAC."
C'est mentionné nulle part dans la mode d'emploi.
Mikhail M.
À l'attaque ! :-))
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-the-topping-d70-dac.7694/
Le DAC Topping D70 embarque de nombreux raffinements propres à un produit audio haut de gamme. Puces performantes, horloges ultra faible...
