Benjamin Daniel S.
Unbelievable - most important part of my CD chain
My Teac CD player was connected direct to a Goldenwave Serenade via Coax/SPDIF. Since the Serenade has no internal spdif...
Nathan G.
Tout marche
Au top, simple à mettre en place, tout est fourni. L'alimentation en suggestion est bien compatible. Je recommande !
Marylène C.
stable et efficace
Utilisé depuis environ 1 an pour gérer le filtrage entre les enceintes et un caisson en passe haut et passe bas, utilisation...
TOPPING D90 III DISCRETE DAC Symétrique Discret Bluetooth 5.1 32bit 768kHz DSD512 Noir - avis - Il y a 2 avis.
Sandu T.
Super !
Super DAC, looks identical, but they don't do the same thing :) It sounds very good, it's worth it! This company has made me a fan forever. Bravo to the engineers! With love from Romania!
Poul T.
This one is different!
This is not an audiophile DAC, but a mastering DAC that opens a window into the mix. Used with USB it is extremely transparant and resolving and that is definitely both good and bad as I have found out. It simply cannot be compared to other DAC´s at the pricepoint, because you get a much different experience of hearing the music.
Some records sound much worse, some flat sounding records are brought to life and many records have spookely lifelike timbre.
I am not sure I can recommend it in general, but I am definitely keeping mine :-)
 (4)
Le DAC symétrique D90 III Discrete de la marque Topping se veut être le pendant du D90III utilisant un module de conversion...
