Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
TOPPING G5 Amplificateur Casque NFCA DAC ES9068AS Portable Bluetooth aptX HD LDAC Noir - avis - Il y a 1 avis.
Fabien T.
Bien mais
I've 3 issue with it:
1 - It will not charge with USBC PD charger.. you need an additional cable / charger.
2 - It is not detected on my iPad if not powered down and up.
3 - The maximum volume is lower with iPad over USB (BT is Ok) even with max volume set.
I hope topping will fix at least iOS issue. And if it can fix the charging one it can be a real replacement of my NX4DSD.
Topping présente avec le G5 un amplificateur casque et DAC portable à la fois compact et performant. Celui-ci...
