DIMOKRITOS D.
Dynamic and very detailed but excessively bright in midrange and highs
It’s a very good option for powered subwoofers, due to its powerful and very well controlled bass, and that is the only reason...
Marcus L.
Amazing value
The performance of this DAC is exceptional for the price - amazing value! It beats most of the DAC’s I’ve either owned or...
Konstantinos L.
Another happy customer
After 30 years of enjoying my father's premium JVC amplifier for my home PC setup, I finally decided it was time for an...
XDUOO XD05 BASIC Amplificateur Casque DAC Portable ES9018K2M XMOS 32bit 384kHz DSD256 - avis - Il y a 3 avis.
Jean-Michel P.
Dt990 Peo
Enfin un ampli qui drive autoritairement mon dr990 pro.
Bel espace sonore de la précision de l'ampleur.
Ça ne vaut pas un audio GD en classe A mais c'est plutôt étonnant.
Fantaisie militaire de Bashung bien respecté ça foisonne c'est détouré un joli aigu.
Une légère redondance dans le haut grave mais sans plus.
L'appareil est un peu gros mais il faut savoir ce qu'on veut.
Bref très bon rapport qualité prix
DIMITRIOS T.
powerful entry-level amp and good dac
It sounds clean and detailed. There is enough power to drive any headphone even on low gain. The dac seems fine and works well when connected to an external amp (this is not a pre-amp so no volume control for the line-out, volume control is only for the headphone-out.) there very little channel imbalance on extremely low volume (you will never listen to that low even with iems) The pachage has all the accesories you would need except from an aux cable (only needed to connect to external amp) there is even a very handy resusable adhesive to use if you want to "glue" this device to your phone or DAP. Battery lasts about 7 hours depending on use so pretty good. There is no hiss or noise even on very sensitive iems although the volume is too much to pair it with such iems, better suited for harder to drive stuff, unless you lower the volume from the phone-computer-dap. Generally Very satisfied with the purchase.
David d.
Parfait, impossible de charger la batterie et de l'utiliser en même temps sans brancher 2 cables
Malgré que ça ne soit pas annoncé il fonctionne parfaitement avec GNU/Linux, il est par contre nécessaire de modifier les fichiers de configuration de pulseaudio ou pipewire pour que l'échantillonage change selon le fichier source. Une fois modifié on voit bien le petit écran afficher l'échantillonage du fichier qu'on lit.
Aucune diférence audible entre PCM1 et PCM2.
Pas pris pour le bass boost, c'est au final une bonne surprise qui est bien utile selon le genre de musique et les casques audio.
Seul petit bémol le port USB pour les données sert uniquement aux données, il ne peut pas alimenter l'appareil, il faut donc aussi connecter le port d'alimentation si l'on ne veut pas décharger la batterie.
Autrement le son est très propre et même 600 ohms ne sont pas un problème.
Testé aussi avec une OP Amp TI LME49720NA/NOPB, pas vraiment de différence audible mais ça fonctionne aussi bien.
Avec un Surfans F20 en USB il y malheurement de petits artefactes, mais c'est le Surfans qui est en cause.
xDuoo présente avec son XD-05 Basic un petit amplificateur casque et DAC portable, abordable mais pourtant extrêmement...
