BURR BROWN OPA627 AOP Double (deux simples) sur Support (Unité)
Référence : 8434
7,50 €TTC
6,25 € HT
Date d'expédition : 01-04-2025.
Ce produit est constitué d'un aop double au format DIP constitués de deux OPA627 simples sur le même PCB (un dessus, un dessous).
Produit basé sur des OPA627 reconditionnés.
Ces AOP ajouteront davantage de détails et de clarté au signal sonore.
Vendu à l'unité.
Datasheet AOP627
https://www.audiophonics.fr/images2/8434/8434_opa627_pcb_1.jpg
Type AOPSimple
20 avis
Great improvement on Fosi ZA3
I have purchased these op amp to replace the stock op amps on my Fosi ZA3 and ZD3. These greatly improved the sound quality of ZA3. For ZD3 stock op amps, LME49720 sounds better than Dual OP627.
Cet avis a été posté pour BURR BROWN OPA627 AOP Double (deux simples) sur Support (Unité)
Perfect Opamp
Clearly hearable difference with AUNE default Opamp. Very smooth and detailed sound
Belle surprise
Le son est détendu et bien contrôlé avec une séparation légèrement prononcée des voix et des instruments. Écoute en finesse.
Bien meilleur que les NE5532.
Je pense acquérir une paire de Opa2604ap pour comparer
Hungary
The point is, I think it was worth it. Its sound is almost creamy, it packs the instruments into the space better + I feel it is a little more detailed, more listenable (analog), more lovable in the long run. Of course, this is just my opinion. I made a loose video, unfortunately, due to the high compression, the difference doesn't come out as much as in reality, but once I've "worked" with it (rather played it), I'll share it. .., have fun with it: https://youtu. on/sZKlYxdNpoo
The best of the best in its class
Super cheap price that makes any DAC sound acceptable (entry level Hi-Fi). The sound is relaxed but confident and well controlled with a slightly pronounced separation of vocals and instruments. From a very cheap built-in DAC, you will notice that the sound is no longer so compressed, it has become freer. I think this OP-Amp could be compared with any budget external DAC, but definitely better than the built-in one of Wiim streamer, cheap phone or headphones. This OP-Amp is the first one that produces a different sound from the ones included in the Aune X8 set (I compared).
