Not easy to work with
Be aware that this solder needs A LOT of heat and is pretty large in diameter. I had to set my iron to ~400C to solder some RCA plugs with it, so if you are working with temperature sensitive components I would not reccommend it!
Cet avis a été posté pour WM AUDIO Étain à Souder Soudure Argent 3.8% 100g Be aware that this solder needs A LOT of heat and is pretty large in diameter. I had to set my iron to ~400C to solder some RCA plugs with it, so if you are working with temperature sensitive components I would not reccommend it!
