...But you will have to cut the solder between the ''H'' and the center point at the power-Supply section and solder the ''A'' point to the center point. This is necessary to use this board Power-supply which will deliver the 3.3 V DC to the ICs. Initially, using the ''H'' to center point connection you will use the HDMI cable voltage provided by the Source, in my case it didn't work because the Source provided only 1 V DC. I hope it helps. Enjoy!
 ![[GRADE S] IBASSO DX240 Baladeur Numérique HiFi DAP DAC ES9038Po Symétrique Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Noir](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-baladeur-numerique-hifi-dap-dac-es9038po-symetrique-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-noir.jpg)
 ![[GRADE A] AUNE S17 PRO Amplificateur Casque / Préamplificateur Discret Class A Symétrique 7500mW @32Ω Noir](https://www.audiophonics.fr/69093-thumb_default/aune-s17-pro-noir.jpg)
 ![[GRADE S] MINIDSP FLEX HT Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS HDMI ARC eARC](https://www.audiophonics.fr/68133-thumb_default/minidsp-flex-ht-stockb.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Amplificateur Casque Discret 5W Bluetooth LDAC aptX HD 32bit 768kHz DSD512 MQA Noir](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-amplificateur-casque-discret-5w-bluetooth-ldac-aptx-hd-32bit-768khz-dsd512-mqa-noir.jpg)
 Français
 Français  English
 English
