ALPS RK09 Potentiomètre 2 Voies + Interrupteur 3A 10K Ohm
4.0 / 5
Référence : 5806
8,50 €TTC
7,08 € HT
Potentiomètre ALPS RK0971221Z05 10k 2 voies + Interrupteur
Potentiomètre logarithmique avec interrupteur 3A
Number of resistor elements Dual-unit
Mounting direction Horizontal type
Shaft types Flat
Length of the shaft 15mm
Center detent Without
Total resistance 10kΩ
Resistance taper 3B
Operating temperature range -20℃ to +70℃
Electrical Performance Total resistance tolerance ±20%
Rated power 0.05W
Maximum operating voltage 50V AC, 10V DC
Maximum attenuation 80dB min.
Gang error -40dB to 0dB 3dB max.
Insulation resistance 100MΩ min. 250V DC
Voltage proof 300V AC for 1 minute
Mechanical Performance Total rotational angle 300±5°
Rotational torque 2 to 25mN·m
Stopper strength 0.5N·m
Push-pull strength 100N max.
Vibration 10 to 55 to 10Hz/min., the amplitude is 1.5mm for all the frequencies, in the 3 direction of X, Y and Z and for 2 hours respectively
Solder heat resistance Manual soldering 350℃ max. 3s max.
Dip soldering 260±5℃, 5±1s
Durability Operating life 15,000 cycles
Environmental test Cold -30±2℃ for 96h
Dry heat 70±2℃ for 96h
Damp heat 40±2℃, 90 to 95%RH for 96h
Specifications switches Contact arrangement SPST
Changeover angle 50° max.
Operation torque 50mN·m max.
Ratings 3A 16V DC
Contact resistance (Initial period/After operating life) 100mΩ/200mΩ
Operating life 10,000 cycles min.
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_1.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_2.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_3.jpg
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_4.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_5.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_6.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_7.GIF
https://www.audiophonics.fr/images2/5806/5806_RK0971221Z05_8.GIF
Canaux2 (Stéréo)
Résistance (Ohm)10000.0
Tolérance (%)20
FOnctionne bien
Il y a ambiguité sur le site : on ne sait pas s'il est avec ou sans inter. Finalement le modèle reçu est avec interrupteur.
Cet avis a été posté pour ALPS RK09 Potentiomètre 2 Voies + Interrupteur 3A 10K Ohm
