Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
Customers reviews - There are 18976 reviews.
claude N.
ELECTRO-HARMONIX 6H30PI Gold Pin Tube Twin Triode (Unit) The 6H30PI Gold Pin from Electro-Harmonix is a double triode tube. Its low plate resistance combined with excellent linearity and a dissipation of 4W per plate make it a prime...
Mon ampli intégré acheté récemment Hybride Consonance a 120 Son tube Sovtek 6H30 HS au bout de 10 jours..étant en rupture de stock chez Audiophonics..J'ai commandé le Electro-Harmonix pour 10€ de plus..Mais quelle surprise..Je trouvais l'ampli pas assez chaleureux et légèrement remontant..Avec le Nouveau Tube EH..c'est superbe..chaleur..aigu à sa place..Médium fabuleux..
Frederic G.
Tube GZ 34
Remplace avantageusement une valvo
Frederic G.
Quad Tung sol
Tube tre musical ,un son détaillé et plus doux que mes précédents tubes nos S....
jevgenijs S.
FURUTECH FT-SDS (G) Power Plug Schuko Type F for Power Distributor Gold Plated This Schuko Furutech FT-SDS(G) sub-base is intended for installation in a power distributor. The high quality pure copper contacts with gold plating ensure excellent electrical...
significant change
SQ has significantly changed in comparison with an older wall socket. Base got deeper and mid top region got the second dimension. Fully satisfied with purchase. Big thanks to Vlad form Unison audio saloon in Riga Latvia for installing this socket!
Peter M.
PANGEA AC-14SE MKII Power Cable Triple Shielding Cardas Copper / OFC 3x2mm² 1m Based on a mix of sale strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source...
Solid Power Cord
I find this power cordHello,
I have replaced all my (common / freebie power cords that usually come with units) with Pangea (one by one).
I done it in several purchases (different lenghts).
I find this power cord(s) quite suitable for my stereo system, myself and my wallet.
(I have avrage components: Denon, Audio technica, Focal)
????I like:
well build construction
flexible cable (behind rack and furniture)
elegant connector in to audio unit (turntable, CD player, .. )
compact and bulky connector in to (wall socket, power strip, ..)
afordable price
nice looking design
It work nicely,
delivering electricity to units and protect from unwanted disturbances.
They serve me well and I am very happy with those.????
Of course, there are also others power cords on market if you desire:
better structure, better materials, better ... ,
... with better/higher price! ????
Francois g.
tres bons jumper
Ces jumpers ont remplacé du basic ohelbach avec bonheur. Cest cohérent, consistant, bref c'est bien mieux sans se ruiner.
Francois g.
pas facile a souder
Si vous dever souder un fil avec la tresse de protection, alors il faudra vous armer de patience car il ny a pas assez d'espace. Sinon pas de problème si on ne souder pas la tresse. Sur les Neutrik pas de soucis....
JEROME P.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
Service client parfait
Commande livrée en 24 heures. Matériel conforme mais mal traité par le transporteur donc arrivé abimé.
Création du litige et renvoi du nouveau le jour même. Echange reçu sous 24h !
Bravo pour le service client. Au top!
Merci.
arnaud g.
bon matériel
FIni bien le cable zef speaker.
AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that...
Casque mais aussi préamp ligne exceptionnel ...
Son chaud, beaucoup de matière et présence, belle transparance et définition, spatialisation 3D
Très surprenant pour le prix ... !
Je revends les autres pré achetés précédemment ...
Ils ne tiennent pas la comparaison ...
Me rapelle mon regretté Musical Fidelity F2, mais l'Audio GD va plus loin en terme de transparence, comme le F2, on penserait qu'il y a des tubes ... et bien non ... !!
Juan C.
FURUTECH FT-SWS-D NCF (R) Dual Power Plug Schuko Type F Rhodium Plated Copper NCF The Furutech FT-SWS-D NCF (R) is a dual wall socket with Schuko high-end connectors. Its high design quality allows it to provide an undegraded AC electrical signal that greatly...
La cerise sur le gateau
Je pensais avoir déjà atteins l'optimum sur mon installation. He bien cette prise Furutech m'a détrompé. Plus de diaphonie, un équilibre et une sérénité dans la reproduction incroyable. La musique apparait tout simplement naturelle et évidente. Je recommande.
Pascal A.
J'ai remplacé le cable bricomarché de mon enceinte centrale, pas ce cable. Les dialogues sont devenus d'un seul coup plus clair, et l'effet woofie de l'enceinte centrale à disparu. Surprenant à ce prix.
Harry H.
up occ copper cables
I ordered this cable after having very good results with the NEI 3004 interlink cable. I used for this cable the AECO pure copper RCA plugs.
I am curious what the NEMOI 3220 with AECO ARP-4045 RCA plugs will do in my setup. I will come back as soon as the interlink is ready and is listen at.
I have not been listening to it
Jean-Marie L.
pins trop fins
La matière employée est robuste (céramique) mais attention à ne pas la laisser tomber sur du carrelage, elle pourrait se casser comme du verre. Cela dit, on peut souder du câble sur les pins sans que tout ne se mette à fondre autour ... le problème est que les pins (broches) sont de diamètre # 1,75 mm, alors que les ceux des EL34 sont de # 2,30mm. Donc l'enfichage sur les embases de tubes de mon ampli à lampes est trop lâche et source de mauvais contacts (risque d'arcs). Il doit être possible de rattraper la différence en recouvrant les pins avec de la soudure, mais ce n'est qu'un pis-aller. Dommage ...
GONZALEZ POZO J.
Dinero recompensa de fidelidad no utilizada
Yo hice este pedido pero lo anule por falta de stock del producto. Utilice el dinero de la recompensa de fidelidad pero en realidad al anular el pedido no lo utilicé. Ahora voy a comprar y no veo este dinero. Por favor me gustaría recuperarlo para utilizarlo en la siguiente compra. Gracias
En rodage
Câble monté sur le hp du grave
Besoin de rodage mais prometteur
william l.
AUDIOPHONICS HPA-S600NC Power Amplifier Class D Stereo NCore NC500 2x600W 4 Ohm The HPA-S600NC is an impressive stereo amplifier. It is designed to meet power and precision requirements. Based on a duo of Hypex NCORE NC500 modules, this Class D amplifier...
Appareil reçu dans les temps dans un emballage sérieux.
Le boîtier et la connectique sont de qualité, l'éclairage du bouton marche/arrêt gagnerait à être plus discret.
Les performances de cet ampli sont impressionnantes, clarté et puissance sont au rendez-vous, pas le moindre souffle dans les hp et l'ampli ne chauffe pas.
Un grand merci à David et Grégory pour les conseils et leurs patiences face à toutes mes questions.
Leandros B.
Nice cable
Nice cable in a reasonable price
Leandros B.
A bargain
Probably one of the top vfm IEC
Leandros B.
NEOTECH STDCT-18 Hook-Up Wiring Multi-Strands UP-OCC PTFE 0.8mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
Excellent cable
Crystal clear and punchy sound. I use it for connecting the PSU with the phono preamp of a Lehmann silver phono.
Morgane M.
DAYTON AUDIO HTA100BT Hybrid Tube Amplifier BT5.0 Phono 2x50W / 4 Ohm The HTA100BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date connection including no less than a...
Une belle surprise
J'ai beaucoup hésité à acheter cet ampli. Mon précédent appareil dont j'étais si satisfaite, je cherchait quelque chose de joli, qui sonne bien avec des connectiques diverses. Ce petit Dayton Audio cochait toutes les cases : design rétro comme j'aime avec le préampli à lampe, un encombrement optimal, une entrée phono, une optique, une RCA et une connexion Bluetooth. Tout cela pour moins de 300 euros… J'ai cherché des avis mais n'en ai trouvé que sur Amazon.uk et le produit n'était plus disponible. Les avis étaient plutôt positifs. Grâce au retour possible sous 14 jours du site Audiophonics, je me suis laissée tenter.
Le suspens était à son comble : 30 jours pour un réapprovisionnement de l'article mais le service client du site est actif et réactif, ce qui m'a rassurée.
Le colis arrive enfin en parfait état (merci au transporteur). Je l'ouvre : connectique anglaise ! Encore un peu d'attente pour le brancher avec un shuko.
Première écoute : plutôt pas mal pour le prix ! J'ai entendu mieux mais super dynamique sur les enceintes Sony vintage APM22ES. Des aigus plutôt clairs et timbrés. Il manque un peu de détail dans les médiums. Les basses sont rondes et dynamiques. La couleur est assez chaude grâce à la pré amplification à lampe. L'ensemble est vraiment bien pour ce prix et mon ensemble est un régal pour les yeux. Du coup, j'ai branché ma Technics MK2, ma box internet en optique (associée à mon vidéoprojecteur pour l'image, c'est du bonheur sans problème de latence), ma platine CD en RCA et le gros plus : la connexion Bluetooth est parfaite et Deezer sur mon téléphone tourne en continu avec un son assez bluffant.
Les petits bémols (oui, ii y en a mais ils sont anecdotiques) : Pas de télécommande : il ne faut pas avoir des problèmes de dos s'il est installé près du sol. Une fois le canal sélectionné, l'ampli se reconnecte au Bluetooth de l'appareil appairé systématiquement une fois donc il faut resélectionner le canal initial. Le sélecteur de canal sur la face avant est blanc froid alors que les lampes et les vu-mètres sont jaunes.
En conclusion : très belle surprise auditive et esthétique pour cet achat au prix raisonnable eu égard aux diverses connectiques et à la bonne qualité sonore.
Rachid C.
WONDOM JAB3+ AA-JA32173 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio...
Trés agréablement surpris
Le rapport qualité prix est très intéressant. Acheté à l'origine pour un projet d'enceintes portable, je le trouve tellement bon que je l'utilise désormais à la maison. Couplé au module de programmation (ref AudioPhonics 15703) et au logiciel SigmaStudio, il est possible de faire des configuration spécifique pour chaque enceintes ou lieux d'écoute. Le kit de câble très complet qui va bien, référence Audiophonics 15065.
Rachid C.
Pour le prix, ce petit DAC remplis très bien sont rôle.
vincent M.
SHANLING M6 ULTRA Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Black The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above all marking the return of AKM...
top
J’ai un peu d’expérience en casques / audio ayant démarré il y a plusieurs années avec un Grado PS 1000, puis focal, puis D8000 et maintenant un Meze Elite.
Donc reçu ce matin le M6 Ultra, un peu galère pour l’utilisation en mode DAC USB -il n’accepte pas la connexion directe en usb-c, et il y a de la latence entre le PC et le lecteur, mais rien de bien grave.
Mise à jour du firmware, installation de spotify, upload de flac et dsd et je troue la synergie franchement réussie entre le Meze et le Shanling (prise en 4.4mm). tout est vraiment bien détaillé, sans être analytique, bonne pèche sur tout le spectre, parfait pour mon écoute / musique électronique / rock / classique ou hard-rock.
Franchement pour le prix c’est un super lecteur portable, simple d’utilisation et bien fini mais qui peut (dans mon cas) remplacer un setup dédié de desktop.
Bertrand S.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Black The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
Compact et efficace, Bluetooth hs
Utilisé pour des enceintes de bureau faites maison pour alimenter des Hp de voiture de 40 w RMS montés dans des caisson. ca marche super bien câblé, Pour ce qui est du Bluetooth, impossible de le faire fonctionner.
l'appareil est détecté par mon téléphone mais impossible de l'appairer. il indiquent dans la notice une application pour le faire fonctionner mais qui est ecrite tout en Chinois et impossible de faire une traduction, amoins que vous sachier le parler et l'écrire, c'est inutilisable.
il est important de souligner la taille du produit sur le site, ou je m'atendait a beaucoup plus gros, a ma grande surprise il fait 10.5 cm par 9.5 cm sur 3 cm de hauteur.
Pour conclure, compact, efficace rendu du son ok, bluetooth ne fonctionnant pas. bien construit tout en métal.
rien a dire en cablé.
Laurent C.
Très bon mais pas parfait sur ma configuration
Ça fait des années que j'utilise des Qed signature revelation (très bon et pas agressifs malgré une pièce assez claire, un manque dans les infra graves) sur divers amplificateurs et des Focal aria926. Les atohm comblent ce manque avec des basses bien pleines et imposantes. J'ai écouté c 2 câbles en même temps un à droite un gauche.. c le top !!! Le qed apporte clarté et grande profondeur (ce qu'il manque un peu sur atohm) et lui le grave. J'ai plus qu'à trouver le câble qui m'apportera tout à la fois...
Jorge m.
Muy bien
He comprado esto desde España en dos días lo tenía en casa. El aparato funciona muy bien y es muy práctico lo de los dos interruptores
Pavel J.
SINGXER SA-1 Headphone Amplifier Preamplifier Class A Balanced The Singxer SA-1 is a high-performance, full-featured headphone amplifier and preamplifier based on Class A architecture and discrete, fully balanced circuitry. Completely...
Excellent discreet balanced amplifier in the price/performance ratio.
The SINGXER SA-1 is an excellent headphone amplifier and preamplifier for active speakers.
Its quality surpasses, for example, the cheaper Schiit Jotunheim 2 or MONOLITH THX AAA-887. If you want a better amp, go for more expensive ones like Burson Audio Soloist 3X Performance or HeadAmp GS-X Mini.
If you are going to use the SINGXER SA-1 in combination with a DAC, I recommend choosing one with enough power to drive the SINGXER SA-1 amplifier. I use it with the powerful RME ADI 2 DAC FS via balanced XLR cables and I am extremely satisfied. Other recommended DACs are Denafrips Ares II, GUSTARD X26 PRO.
I use HiFiMAN Ananda Stealth and HiFiMAN Sundara headphones. Other headphones I would highly recommend for this amp are the more expensive HiFiMAN Arya Stealth, Audeze LCD2 and LCD-X or Focal Clear Mg.
The sound of SINGXER SA-1 is very very clean (almost dead silent), detailed, smooth and warm with a lot of space, separation of instruments and soundstage.
I highly recommend this amp for purchase at a great price!!!
Rene C.
Best buy
Reasonable priced, high quality EMI filter
Rene C.
Best buy
I recommend the use of this cable in all solid installations, fx. inside wall sockets, to and from or inside power strips .......
Viorel S.
Station solder Blanko ZD-931
Come fate a dire che questa stazione saldante è una professionale? Io l'ho comprata qui da voi è non a neache un anno di vita è già non funziona più, le punte dopo 2 giorni di utilizzo, li devi buttare perché si consumano rapidamente. Una stazione pessima meglio la mia 100 volte che l'ho pagata 20 euro. I soldi adesso chi me li ridà? Ovviamente nessuno. Ma così fatte soltanto figuracce rispetto alla gente. Già siete poco seri ero un vostro cliente ho dovuto cambiare strada.
Iulian M.
Verry good opamps
Replaced the default JRC 5534 's in burson playmate 2.
Very good transparency.
Vivid's reveal rough edges in the audio setup so if you can't stand to listen with them then you have some more work to do on your setup.
Jose l.
plus de clarté
brancher sur l'alimentation indépendante de ma box, je vais en reprendre pour mes amplis.
Jürgen K.
Excellent!
The cable is really fabulous, hasn`t fully broken in yet, however the quality is already noticeable. Compred to Neotech NES 3002, which is not bad at all, I noticed clear superiority of RAMM in female vocal. Absolute clarity and no sizzle in "S". As well as bass is well defined, sharp and weighty. All in all a lot of value for money. Great PRAT, snappy, airy, detailed. Bravo!
Emmanuel A.
FIIO FD1 In-Ear Monitor IEM Beryllium Plated Dynamic Drivers With the FD1, Fiio offers high-quality in-ear headphones at a reduced price. They benefit from a careful design to offer a rich and immersive sound reproduction, as well as an...
Ecoute très agréable, équilibrée.
Tres confortable, avec un spectre étendu ( non mesuré ) qui semble préservé. Une belle dynamique.. Par rapport a d'autres marques pour ce meme budget, les graves descendent bien, les médiums ne débordent pas, et les aigus, voix, cymbales, sont claires et précis. L'essentiel est surtout d'offrir une belle musicalité.
Samuel B.
QULOOS QA690 FDA Power Amplifier 24bit 192khz 2x100W / 8 Ohm The Full Digital Amplifier FDA QULOOS QA690 is the worthy successor of the QLS QA-100, the first affordable FDA amplifier on the market that is unanimously acclaimed by its users.
1er FDA pour moi, donc la comparaison ne se fait qu'avec des amplis analogiques (NAD C 356, Hegel H 80 de mémoire) et il les surpasse aisément. Je le trouve excellent, son limpide, détaillé, et bien équilibré. Je sens aussi une grande réserve de puissance, ce que je cherchais (à 25 sur 78 très exactement, c'est déjà énorme pour ma pièce d'env 60m2, et je sens que l'on peut encore monter sans saturation/distorsion).
Très content!
nicolas s.
Excellent ampli FDA !!
Rapport qualité prix incroyable. Cet ampli procure vraiment du plaisir. Précis et suffisamment puissant pour une majorité des enceintes et pièces d'écoute. Je me permets de partager un test audio réaliste pour donner une idée du rendu, à écouter avec un casque ou écouteurs : https://youtu.be/jVVeyU2VsB0. Bonne écoute et merci à Audiophonics pour leur service et conseils.
Stephane N.
Utilisé pour la réalisation de câble XLR modulation, sans blindage extérieur supplémentaire, le rendu est excellent ( liaison ampli NCore et Dac Sabaj ).
Énormément de détails sur tout le spectre.
Vraiment un must.
Stephane N.
NEOTECH BRDCC-20 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 20AWG 0.5mm² Neotech BRDCC wire is an excellent UP-OCC Copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and...
Bonne idée mais…
Impossible pour moi d’insérer les câbles Neotech argent SOST 22 au delà de 5 cm.
Déçu.
Florent D.
Acheté pour remplacer un kit elektor ampli/filtre Sub (trop fragile: pistes décollées, irréparable), cet ampli classe D est étonnant: graves fermes et moins empâtés qu'avec mon vieux kit elektor. Il descend bas et tient bien le HP grave.
Sensibilité d'entrée un peu plus faible que celle de mon kit elektor. Pour finir il rayonne un peu en HF: j'ai un recepteur DAB et j'ai du éloigner l'ampli et l'orienter dans un certain sens pour eviter les pertes du signal DAB.
Florent D.
Très bon produit, qualité pro: circuit imprimé epoxy double face trous métallisés, du solide.
Composants de qualité.
La tempo haut-parleur est de 6 à 7 s. lorsque le circuit est hors tension depuis 'longtemps'.
La protection tension continue est entre 2 et 3 V.
Voir les commentaires de Jean Pierre G. que je confirme ici, 'à ce prix c'est imbattable'.
L'idéal est d'installer ce module avec le transfo pour le 12 V alternatif commandé
par le même interrupteur secteur de l'ampli:
l'alimentation doit se faire par du 12 à 18V alternatif,
ceci parce qu'à la coupure d'alim les relais s'ouvrent immédiatement
(avec du continu il y a toujours une capa. balast qui maintient l'alim pendant 'un certain temps'),
cela permet d'éviter les plops à l'extinction.
Sebastien D.
SHANLING MTW100 In-Ear Monitors IEM Bluetooth 5.0 Black The Shanling MTW100 headphones, particularly practical, allow a stable and efficient transmission of your music. Knowles loudspeakers and the intelligent design of these IEMs...
tres bien
un rapport qualité prix défiant toute concurence, malheuresement apres 4 ans d'utilisation intensive au taf un des écouteurs commencait à rendre l'ame (gresillements) , je me suis donc retourné vers les mtw300 car les mtw100 n'étaient plus en stock à une période sur le site et je regrette de n'avoir pas été plus patient...
Sebastien D.
SHANLING MTW300 In-Ear Monitors IEM Bluetooth 5.2 QCC3040 aptX Grey The Shanling MTW300 Bluetooth in-ear earphones feature the ergonomic and comfortable design of the MTW100, in a version with enhanced performance. For example, the integrated...
bof
Venant des mtw100 je prefère ces derniers, le son est bien meilleur certe sur ceux ci mais l'appairage est un brin ennuyeux à cause de l'aptx qui se reconnecte et déconnecte régulierement dès qu'il repère d'autres sources bluetooth , vraiment dommage car le son y est...
charles Z.
Excellent à mes oreilles !
Expédition : délais annoncé tenus, très bien emballé. Appareil acheté en juillet 2022.
Qualité de fabrication: aussi beau a l’extérieur qu’à l’intérieur. Je l’ai ouvert quelques fois pour régler le gain et la construction est vraiment soignée. Les tôles qui constituent le boîtier sont épaisses et les ajustements sont propres.
Le plus important : le son, la Musique.
Deux mots sur ma config:
- enceintes Thiel 3.7
- streamer Auralic Altair G1 branché en direct sur l’ampli via XLR MIT
- barbette filtrée et câblages Audiophonics et MIT pour les enceintes.
L’ampli ne laisse rien passer, il est très (trop) transparent, et la qualité de la partie preampli sera importante dans votre installation. J’avais auparavant un Meridian G08, je trouve que l’Auralic va plus loin, et l’ampli suit sans sourciller.
Tenu des basses incroyables, les médiums et aigus vont très loins aussi.
Ce qui me frappe le plus, c’est la dynamique et les extinctions de notes: rapides , fluides sans jamais tronquer la musique.
Sur mon système, le son peut paraître analytique et j’essaierai sûrement un preampli à tube ou une grosse électronique japonaise, pour voir… ou plutôt écouter.
Reste que mon ancien système semble bien obsolète ( blocs mono Rega Exon) et que mon fils de 9 ans m’a dit hier soir: qu’est ce que t’as fait à la musique papa? C’est bien mieux qu’avant ! Avec le pied qui battait le tempo sur un Clapton…
La vérité ne sort’ elle pas de la bouche des enfants ?
Simon N.
SIVGA Headphone Cable Jack 3.5mm to 2x Jack 2.5mm Mono OCC Copper 1.8m This Sivga cable has been designed to accompany HiFi headphones with detachable cable. It has two mono Jack 2.5mm connectors and one Jack 3.5mm stereo connector. The...
Faux contact après 3moi
Le câble avait l'air de bonne qualité mais un faux contact est apparu après a peine 3 mois d'utilisation (je pense que c'est à cause du fait que le câble soit trop fin et qu'il ait tendance à se torsader)
Boitier 3U
Excellent coffret, la qualité est toujours là.
Dommage que les vis tôle de fixation du capot et du dessous soient d'un diamètre légèrement trop petit et ne permettent pas un serrage avec léger blocage.
A part ça, épaisseur des tôle et rigidité des plus satisfaisants.
Jean Claude L.
Exceprionnel !!
Monté avec des fiches KLEI Silver en masse flotante.
Ce câble a détrôné des modèles à plus de 1200€.
Époustouflant.
Très dynamique , grande transparence, profondeur de la scène sonore, détaillé, bande passante , précis et clair, tous les critères d'un excellent câble sont réunis à un prix dérisoire.
Grande musicalité !!!
Une constante chez RAMM.
Même niveau que leur Amadeus 5 (utilisé en secteur )
Laissez tomber les pseudos référence à pas de prix, ne cherchez pas, tout est concentré dans ce câble
Jean Claude L.
Heat-shrink tubing 3:1 Ø12.7mm Transparent (1m) Thermo-retractable sheath with a ratio of 3: 1, internally equipped with an adhesive layer ensuring better support on any type of surface (plastic, rubber, metal ...)
De la qualité
Produite de grande qualité
Très bonne qualité , de bonne épaisseur, pour une finition professionnelle
Jean Claude L.
Correcte
Rapport Q/P correct
Jean Claude L.
Bon produit.
Il faut juste bien respecter la température de fusion pour
de belles soudures
