Markus W.
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price...
Patrick v.
Magnifiques !
Tom K.
Customers reviews - There are 18954 reviews.
Gaetan P.
DYNAVOX Banana / Spades Jumpers OFC Copper 2x2.5mm² 25cm (Set x4) These top-of-the-range Dynavox jumpers are perfect for linking your audio installation in bi-wiring or for series connection. Each jumper is 25cm long, with two 79-strand 0.2mm...
Parfaits mais ... attention vous choisissez bananes ou fourches ... trop court pour les faire des cables hybrides (c'est un détail)
Ils sont parfaits et respirent la qualité
Merci Audiophonics
George R.
Excellent sound & exceptional value for money
What an impressive amplifier! Dead silent - both mechanically and electrically. Well-constructed. Detailed, open & dynamic sound. More power than needed for my Proac speakers. I have owned many amplifiers over the years and this has to be the best value for money!
George R.
Exceptional sound quality
I also have an "LPA-S600NCX" stereo power amplifier and wanted to compare the two concepts. I really struggle to determine if there is a repeatable difference between the two amplifiers. On certain tracks I feel that the Purifi is slightly more relaxed & natural and on others feel that the Hypex is a bit punchier in the bass. However, I am not confident that these subjective observations are repeatable. Both amplifiers are neutral (in a positive way), musical & silent. The one noticeable / repeatable difference is that the Purifi is cooler to the touch. Save a bit of money and buy the Hypex ncx? You cannot go wrong with either - both are exceptional amplifiers!
Michael M.
Burson v7 vivid
This opamps are amazing. I installed a pair in my musical fidelidy trivista dac and the detail that they gave to the sound is extraordinary!!!
Alain M.
Livraison dans les temps et emballage soigné.
Je suis bluffé par l'apport sur la qualité de l'écoute.
Précision, netteté et ouverture de la scène sonore.
Câble de très belle fabrication.
Merci Audiophonics pour votre sérieux
Pierre P.
BURSON AUDIO V7 VIVID PRO Dual OPA (Unit) As an evolution of the V6 VIVID, the V7 VIVID Pro stands out for its clarity, precision and high dynamic range. It is particularly recommended for...
le compromis ideal, à considérer avant toute velléité de changer d'appareil!
j'en ai fait l'acquisition pour tester sur un Dac Burson Conductor 3XP et je ne regrette absolument pas cet achat. l'appareil est littéralement transfiguré par rapport aux précédentes générations V6V. Plus de précision, de définition, disparition des sonorités métalliques qu'on reproche généralement à certains DACs (notamment vis a vis des puces ESS... légende urbaine). on est pour mon système sur un compromis définition/image/matière absolument parfait. pour info, mon système consiste en: Enceintes Martin Logan ESL13a, Ampli Accuphase E650, Mac mini avec Audirvana studio. la transparence des Martin Logan met en évidence le moindre défaut, la moindre trace d'agressivité, et là je me trouve après quelques heures d'utilisation sur une sonorité qui combine enfin un très grand naturel de rescision avec une précision sans agressivité. en bref, avant de céder à la tentation de changer votre sac/lecteur réseau pour une sonorité qui vous paraitrait trop fatigante la longue, et notamment si ce dac est équipé d'une ou plusieurs puces ESS, vous devez absolument essayer ce petit investissement, dont la mise en place ne requière pas de connaissances particulières. la liste des AOP compatibles est très bien renseignée sur le site Audiophonics et vous pouvez faire l'opération de changement sans avoir besoin d'autre chose que d'un bon tournevis ou d'une clé 6pans pour enlever le capot de votre appareil. toutes les opinions colportées sur les puces ESS et leur prétendu manque de naturel sont balayées par la mise en place de ces AOP. et si votre système vous parait vraiment trop agressif, vous pouvez également opter pour la version V7 Classic, qui vous apportera encore plus de douceur, de matière et de chaleur sur les timbres, au détriment peut-être d'une définition moindre et d'une image stéréo moins profonde. en tous cas, je tire mon chapeau aux ingénieurs de chez Burson pour avoir conçu ces petites merveilles, et aux gens de chez Audiophonics pour les livrer avec une qualité de service irréprochable.
Eero M.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Black Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
Great unit
I use it primarily as a dac/preamp for my Genelec monitors and as a dac/hp amp for my Beyerdynamic headphones. Does both jobs well and the unit is pretty compact. No complaints
Jean François N.
Très efficace. j'en ai acheté plusieurs pour mes 2 installations
Jean François N.
Un rapport performance très bon dans cette gamme
De très bonnes performances musicales et très complet.
Les DACs ont fait des progrès énormes il y a 10 ans il aurait fallu sortir 5 à 6 fois d'argent sans compter l'inflation
Jean François N.
Super Produit
Bien fabriquer très bonne restitution entre Audiolab 6000 CDT et SMSL D6S
Jean François N.
Produits bien fabriqué simple et efficace
Jean François N.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Super Produit
Alimente un Zen Ifi Streamer. parfait
Jean François N.
MULLARD GZ34 Rectifier Tube (Unit) The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other...
Audiphonics réagit de façon professionnelle en cas de problème
J'ai eu un problème avec une défaillance sur l'un des tubes.
Le SAV m'a proposé plusieurs solutions au choix.
Il y a un grand respect des clients
Jean François N.
GENALEX GOLD LION PX300B Tubes Power Triodes (Matched Pair) The Genalex Gold Lion PX300B is a high-end triode power tube with incredible audio performance. It is ideal for power amplifier design or as a replacement for equivalent models....
Mon ampli DIY alimente des baffles plans 3 voies.
Les tubes doivent avoir une vingtaine d'heures d'utilisation et fonctionne très bien en espérant qu'elles aient une bonne durée de vie
Jean François N.
Un rapport performance sur prix absolument fabuleux
En remplacement d’un Zodiac Gold Antelope Audio âgé de 10 ans, j’ai été tenté par un Topping ou un SMSL autour de 1000 €.
Mais je trouve que la gamme change trop rapidement chez ces deux constructeurs.
Pour l’écart de prix, les excellents commentaires et différentes revues + la qualité de fabrication, je pensais que ce choix était relativement raisonnable.
L’absence de sélecteur ne me dérange pas pour mon besoin
Je l’ai fait tourner H24 pendant 140 h en suivant son évolution.
Là il commence à vraiment s’exprimer.
Mes composants en aval, dont des enceintes actives pro de 22 ans d’âge m’ont permis de facilement constater l’énorme bond qualitatif à l’écoute, comme constaté dans les autres avis.
Anthony B.
DD TC44PRO Portable DAC 2x CS43131 USB-C Male to Female Balanced Jack 4.4mm 32bit 384kHz DSD256 Following on from the TC44B and TC44C portable DACs for smartphones, DD HiFi has unveiled the TC44PRO, the third generation in its range. It features...
combo meze et earsonics éléments
fonctionne très bien avec Qobuz sur usb audio player pro, j'utilise des earsonics éléments depuis 1 mois le rendu est dynamique et détaillé. à voir avec mes em2pro, quand ils seront revenus du SAV....
Teddy A.
Exceptionnel
Je possède un excellent DAC Erato dont la sortie analogique est en classe A et composants discrets avec toutefois la présence de 2 AOP simple !
Remplacement indispensable pour qu'un circuit audio donne son maximum !!!
Ozren K.
RCA-BNC adapter
The only 75ohm adapter. I use it for coax SPDIF connections with BNC terminated cables. There is a subtle difference, better of course, comparing to other adapters.
daniel c.
chauchau
RQP imbattable. Merci audiophonics pour ce cable asiatique.
Sylvain S.
Excellent produit !
Je viens de réceptionner cet ampli auquel j'ai associé le préampli de chez AUDIOPHONICS, tout cela avec un streamer EVERSOLO DMP-A6. Je possédais auparavant un NAIM SUPERNAIT 3 et je peux affirmer que je suis ravi de mon choix car sincèrement, pour 3 fois moins cher, j'ai quasiment le même niveau de qualité alors que le NAIM est une référence ! Je précise que j'écoute principalement de la musique électronique parfois à fort volume et la tenue des basses est juste parfaite ; je ne savais pas si j'allais conservé le préampli car le réglage de gain de l'ampli au niveau maxi aurait suffit à me satisfaire mais l'ajout du préampli a apporté un plus niveau qualité sonore malgré tout (écoute plus "facile" et ensemble moins criard dans le haut du spectre). Si vous y ajouter la possibilité de changer les AOP et bien franchement pour 1400 euros vous trouverez rarement dans les marques premium HIFI quelque chose de ce niveau de qualité dans cette gamme de prix! Vraiment du super matériel.
Sven B.
LHY AUDIO LPS160VA 19V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical...
Excellent for „ASUS NUC 14 Pro“ with Intel Core U7 155H CPU
EXPERIENCE WITH MY OLD NUC & LPSU:
For my previous NUC I have already used a LPSU delivering 19V/5.25A (AUDIOPHONICS LPSU100 Stabilized Power supply 19V 5.25A 100W NAS / Intel Nuc). The NUC was mainly used as Roon-Server based on Windows (and some other tasks), whereas importantly my DAC was not directly plugged into the NUC! But as a believer in LPSUs in general, I blindly believed in its superior sound-quality compared to the NUC’s stock switching-PSU - but I have never tried any A/B-testing ever since.
EXPERIENCE WITH MY NEW NUC14 & LPSU:
With buying my new NUC (ASUS NUC 14 Pro“ with Intel Core U7 155H CPU), I have instantly ordered the new LPSU delivering 19V/7A. As the LPSU was out of stock, I had to wait a few weeks to finally arrive. In the meantime, I took the chance carefully listening to music using the NUC’s stock-PSU. The sound-quality felt surprisingly good – and therefore I was very excited about the potential of new LPSU.
After arrival in winter the new LPSU was cold and for the first couple of hours it did not seem to leverage any sound-quality. But to my ears the sound-quality continuously improved – and after about 10-20 hours I felt much more pleased (please excuse me not trying to describe any positive effects).
QUESTION & CONCLUSION
Does it make any sense empowering a NUC with a comparably expensive LPSU? (especially, if the NUC is streaming music via network without a DAC being attached directly)
I would say that it depends:
- Yes, if the sound-quality is already rather pleasing using the NUC’s stock-PSU.
- No, if the sound-quality is not already pleasing using the NUC’s stock-PSU, as the sound-signature will not change dramatically. In this case I would rather spend my money on other parts of my equipment prior to buying a LPSU for a NUC. Even though a LPSU does improve a NUCs sound-quality, possibly a DAC, network-switch, USB- or network-card may profit even more.
In my case the sound-quality did seem to have improved and additionally I enjoy the looks and feel of this heavily built LPSU. As I will continue empowering my NUCs with LPSUs in future, I recommend this one without any doubt!
yann r.
XANGSANE SP-8525 Speaker Cable Silver-Plated OFC Copper 2x2.5mm² This Xangsane SP-8525 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
bien pour le prix
utilisé pour le re cablage du tweeter résultat très bien , egue qui monte haut sans être agressif top
yann r.
bien pour le prix
utilisé pour re cablage interne enceinte, résultats :
un très grand bon en avant dans l ouverture, neutre , plutôt musical que détaillé. manque de dynamique, détails et milieux de médium. mais pour le prix pas mal .
Jean-François G.
FOSI AUDIO BT20A Class D Amplifier 2x TPA3116 Bluetooth 5.0 2x90W 4 Ohm The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI TPA3116D2 chips, capable of...
Impeccable pour une TV
J’ai choisi cet ampli pour améliorer le son de ma TV Samsung qui date d’une douzaine d’années, en réutilisant des enceintes Elipson qui dormaient dans un coin.
Pari réussi. C’est pas du 5.1 certes, mais ça me suffit amplement, le son est largement meilleur que celui des hauts parleurs de la TV.
Le seul petit souci que j’ai eu, c’est pour relier les câbles de mes enceintes en 2,5 mm2 car les borniers de l’amplificateur sont un peu petits. D’ailleurs, l’ampli est lui-même riquiqui, c’est assez bluffant de voir qu’un si petit objet puisse produire un son si puissant…
Jean-François G.
Câble pour chaîne B&O
J’ai acheté ce câble pour connecter mon lecteur réseau Cambridge AXN10 tout neuf sur l’entrée Aux de ma chaîne Hifi Bang & Olufsen Beocenter 9500 qui date de la fin des années 90.
Ça fonctionne parfaitement, mais je n’ai honnêtement pas l’oreille pour distinguer une quelconque différence avec le vieux câble pas du tout OFC ni plaqué or que j’ai utilisé quelques jours en attendant celui-ci.
Tout ce que je peux dire, c’est que la construction de ce câble est très propre, rien à voir avec l’autre câble plutôt de style bricolage pour auto-radio ;-)
Sebastien D.
EVERSOLO H1 DAC Portable Headphone Amplifier ES9281AC Pro MQA 32bit 384kHz DSD256 EVERSOLO offers with the H1 a compact and powerful portable DAC and headphone amplifier combo. With a USB-C input, it is an ideal companion for use with a current smartphone. It...
Moyen
Ayant eu la version au dessus qui n'est plus en vente sur le site je suis un peu déçu, déçu que lorsque j'ai voulu enlever le câble Jack tout l'ensemble intérieur du dac est venu avec... Obligé de recoller à la colle forte et surtout la galère à remettre les boutons de volume donc bon dac mais franchement fragile
Gaetan M.
Après 2 semaines d'utilisation je dois avouer que le changement a été immédiatement perçu, cette alimentation linéaire alimente un Octavio Stream, branché sur un Onkyo TX-rz 50 et enceintes Klipsch rp-8000f.
Dès les premières secondes d écoute, on ressent la différence surtout à mi-volume, un son aéré avec plus de détails et de précision sur les instruments.
Cette alimentation est le produit le moins cher de mon installation complète mais sans aucun doute là ou j ai été le plus bluffé par la qualité du son.
Merci à Audiophonics de m'avoir proposé un tel produit pour un prix défiant toute concurrence
Thierry N.
DAYTON AUDIO SPA100-D Class D Amplifier for Subwoofer 100W 20Hz-200Hz The Dayton Audio SPA100-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
Dayton Audio SPA 100 D
Ce petit ampli avec filtre actif convient très bien à l'usage auquel il est destiné. Il alimente chez moi un infraflex de 85 cm de diamètre coupé à 60-70 Hz la fonction bass boost m'est donc sans intérêt. ,A la place , j'aurais juste aimé une option de pente à 24 dB/oct mais la pente de 18 est correctement choisie . La classe D va très bien ici puisqu'on ne lui demande pas de médium. Bon achat.
jean pierre g.
PARFAIT
Merci a audiophonics et son equipe de faire des appareils aussi performants a un prix (abordable).
Un vrai plaisir d'écouter la musique.
A une prochaine sans probleme
Hubert B.
Très bons tubes
Utilisés sur un ampli de puissance Conrad Johnson MV52 en remplacement de JJ Tesla KT77 (avec environ 600 heures de fonctionnement). Je trouve les médiums plus chaleureux et le grave plus tendu. J'avais auparavant des Electro Harmonix 6CA7 qui avaient de très beau médiums, mais des graves pas assez vivants à mon goût. Je suis donc très satisfait de mon achat.
Daniel D.
prise secteur solide et bien conçue
Cette prise Viborg est un très bon produit à l'esthétique réussie, comme ses con-soeurs le montage respire la qualité et la facilité. Cette prise schuko n'est pas la plus détaillée mais elle est à mon sens très neutre avec de belles qualités sonores. Pour la booster je conseille de l'associer avec une prise IEC ETI legato. Le mariage reste neutre mais gagne fortement en transparence.
MOONDROP U2 Earphones Dynamic 14.8mm 116dB 30Ω 20Hz-20kHz With the U2 earphones, Moondrop continues the tradition of quality design and manufacture that has made the brand so successful. With a 14.8mm dynamic driver with a paper...
Excellent pour le prix !
Une fois leur placement bien déterminé dans l'oreille, car ils ne sauront pas s'adapter à toutes les formes (je pense aux petites !), le son est épatant. Très belle linéarité, ce qui est rare pour des écouteurs intra.
Le tube "bass reflex" fonctionne très bien, les basses sont généreuses et précises.
C'est à la lecture de la fiche technique que je me suis laissé tenté car n'étant pas fan des oreillettes (amateur des HD 600 & 530…).
Bref, ils sont devenus mes compagnons pour l'extérieur dorénavant.
Baptiste R.
TONEWINNER AT-300 EXT 5.1 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-300 is a 16 channel audio/video processor and preamplifier, ideal for home theater integration in 9.3.4 or 7.3.6 configurations. It supports all current audio...
Le seul dans cette gamme de prix
5 étoiles par rapport au fait que dans cette gamme de prix il n'y a rien d'autre. C'est simple un Marantz c'est 3 fois le prix ou presque.
Sans prendre en compte le prix. :3 étoiles.
-Démarrage ultra lent avec "clic"
-Calibration bof bof
-Clics entre les morceaux en zappant sur Apple Music
-Contrôles limités via l'écran LCD en mode eARC
Jeremy D.
quand même!
Testés fraichement hier, malgré avoir eu quelques expériences me prouvant l'efficacité de bons câbles, je suis toujours frileux dans ce domaine... j'ai pourtant pû clairement choisir entre deux coax, deux toslink, et là clairement c'est au dessus de mes Qed Silver XT Anniversary qui certes étaient un peu fatigués, le rendu était criard sur BW avec des aigus parfois insupportables! Là tout est plus cohérent, la scène est plus centré, je trouve ca assez fou, j'ai gagné légèrement en basse c'est pas dingue non plus, le fameux "silence" est là, et oui les aigus sont plus doux, saturent moins, le plaisir est là, forcément ca donne envie de toujours plus et c'est là que ca devient compliqué... vous le savez!
Christophe D.
Bonne qualité avec le capuchon souple qui se rabat, après sertissage, sur la cosse pour limiter les accidents éventuels de contacts trop rapprochés.
Christophe D.
HIFI2000 GX388 - 80x330x280 - Facade 10mm Noire The Galaxy models are small housings particularly suitable for mounting active filters, preamplifiers, etc.... The internal useful height is 80mm.
Produit de qualité.
Même sans notice c'est facile à assembler.
Il manque quand même quelques zones non serrables ce qui fait que mon transfo torique de plusieurs kilos fait plier la plaque de support basse. Pas le choix que de placer des cônes juste sous les points d'appui de la charge (transfo) alors que je voulais les placer aux extrémités.
La continuité électrique se fait bien entre chaque face en ne mettant qu'une seule d'entre elle à la terre.
Christophe D.
Bonne qualité et 15A laisse de la marge. Il alimente un transformateur torique de 1400VA.
C'est bien de connaître la nature du métal et son revêtement, pour les cosses de raccordement, afin d'éviter des problèmes de couple galvaniques.
Christophe D.
Il ne manque qu'une chose à cette pince, un mémo pour savoir quelle matrice utiliser sur l'embout à sertir. J'ai souvent utilisé et j'utilise encore ce genre de pince dans mon job mais il y a tellement de matrice que j'ai flingué deux cosses plaqué-or pour un mauvais choix.
Wiesław P.
GUSTARD H16 Headphone Amplifier Preamplifier Balanced Black With the DAC, Gustard offers a high-performance headphone amplifier and preamplifier, benefiting from careful and intelligent manufacturing. With its independent symmetrical and...
bardzo dobry
Potrzebowałem przedwzmacniacza do dac i Gustard sprawdził się znakomicie.Może i nie ma dużo funkcji ale oferuje bardzo dobre wzmocnienie,tak do słuchawek jak i monitorów.
Oncu K.
Great improvement on Fosi ZA3
I have purchased these op amp to replace the stock op amps on my Fosi ZA3 and ZD3. These greatly improved the sound quality of ZA3. For ZD3 stock op amps, LME49720 sounds better than Dual OP627.
Alain S.
Fabuleux !
J'utilisais un tda1541 dans mon lecteur de CD et un ess 9018 dans mon Audiolab 6000a.
Et bien ce petit dac les enterre tous les deux !
Le son est plus détaillé que le tda1541 et beaucoup plus vivant que le ess 9018 !
La différence est époustouflante surtout avec le ess9018.
Basses profondes, bas medium charnu, medium clair mais ayant du corps, aigu filé et aéré.
Écouter la musique à bas volume ne change pas la qualité du son ni sa réponse en fréquence.
daniel c.
chauchau
RQP imbattable. Facile à monter. Merci Audiophonics.
Alexandru N.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear...
Gustard X30
First of all I would like to thank Audiophonics for the prompt delivery and exemplary packaging! It was delivered to me in Bucharest between Christmas and the 31'st.
This DAC is nothing short of amazing. I haven't heard anything like it before.
I can't find a single drawback to it's sound, the stage is deep and wide, the timbre is spot on, dynamics are off the charts with big swings and a really potent bass. I've always thought that the bass can't be very tight in my room because I have no treatment installed, but this DAC proved that it was the source that was keeping my system back in this regard. I don't mean to say that room treatment wouldn't help further, but to some this is not an option.
All of the aspects I've stated are impressive, however, the separation of instruments and voices is on a different level and this makes music make sense.
With this DAC I found that songs I thought were poorly recorded were just not reproduced well by my previous DAC.
Regarding the burn in period that lot's of reviewers mention, it sounded great right out of the box and I was happy with my purchase, but it did improve in the first three days.
Build quality is impressive, but the remote is of poor quality. Luckily I don't use it since I have a separate preamp. Regarding the preamp, it sounds a lot better with a preamp, but this might be system dependent. Going into my preamp if I adjust the volume from the Gustard the sound quality is not affected at all so the volume control inside it is good, but If I take my preamp out of the chain the sound is downgraded from all points of view. My preamp (Benchmark HPA 4) has no gain in the range that I use it in, but it has input and output buffering and it makes any DAC I connect to it sound better. If you've never tried a preamp you will still enjoy the upgrade compared to other DAC's connected directly to a power amp, but if you want an impressive upgrade further down the line get a good preamp.
Simply amazing!
Laurent P.
BFA Banana Plugs Rhodium Plated Ø9mm (Pair) These banana plugs, although inexpensive, benefit from a nice design quality. The BFA design of these plugs allows a very good contact between the connector and the terminal...
très bon serrage et solidité
Pour l'instant à leur niveau qualité / Prix , je n'ai rien trouvé de mieux Très bon serrage et une solidité bien supérieure à tout ce que j'ai pu avoir précédemment. Je les recommande.
Francis B.
Très propre
Le son est vraiment bon. Isolation et blindage efficace. Réalisation soignée! Prix raisonnable. Formidable.
Francis B.
Male XLR 4 Pins to 2x Mono Male Jack 3.5mm Balanced Headphone Cable Silver Plated Copper 1.5m This high-end balanced headphone cable has an extremely careful design using high-quality components. It consists of silver-plated 7N copper conductors, which are insulated and...
Ben voilà. Enfin!
Oubliez le câble d’origine Focal pour les casques Focal Clear avec XLR 4 pin. Le câble apportera l’équilibre tonal qu’on attend avec le clear MG par exemple que j’utilise avec. Et tout sera plus transparent, meilleurs basses . Formidable.
Nikolaus N.
Perfekt
Ich verwende den USB-Adapter so, wie er bei cheap-audio-men empfohlen wurde. Er kommt zwischen dem WIIM ultra und einem DAC (smsl d400 ex) zum Einsatz. Er erwirkt ein unglaublichen Gewinn.
Xavier B.
AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm The Audiophonics HPA-Q250NC is a four-channel amplifier based on two Hypex Ncore NC252MP.
Plutôt bon
L'ampli est plutôt bon, je reconnais que la définition est meilleurs qu'avec mon crown XLS 1502 (plus de micros détails), par contre je ne suis pas bluffé par la différence qualitative, à l'écoute on gagne un peu c'est vrai dans les détails, , mais au vu des critiques et review sur les amplis hypex ncore je m’attendais à un gain qualitatif plus conséquent, je reste malgré tout satisfait de ce nouvel ampli qui s’intègre mieux.
richard L.
XANGSANE XS-LB001 Banana Speaker Cable OCC Copper 2x6mm² 3m (Pair) Xangsane's XS-LB001 speaker cables feature 12 strands of 5N OCC single-crystal copper to ensure perfect conductivity. Each of these 12 strands receives PTFE...
Surprise
Si comme moi vous êtes un adepte du mogami 3103 et bien achetez le xangsane sans hésiter une seconde, il fait tout mieux, et même beaucoup mieux.
Le prix en regard de la qualité est ridicule, bref je suis ravi.
AUDIOPHONICS GXDC-21 Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can be used with LHY power...
Excellent!...
Câble d'alimentation excellent, remplaçant avantageusement celui d'origine fourni avec l'alim. L'amélioration est évidente sur les plans de l'espace, de la densité et des timbres. Indispensable à l'alim pour laquelle il est conçu et construit par Audiophonics.
