Markus W.
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price...
Patrick v.
Magnifiques !
Tom K.
Customers reviews - There are 18954 reviews.
Mark S.
Really opens up with a better power cable
I bought this LPS to replace an Uptone JS-2 which was powering my Mac mini. (The JS-2 was a bit-underpowered --sometimes the Mac mini restarted during heavy updates-- moved to my UltraRendu and EtherRegen. With this Audiophonics LPS's extra amperes the Mac mini no longer reboots.
I initially noticed little difference in sound quality (which is good -- the JS-2 is more expensive and for my Mac mini this LPS sounded similar). I have since experimented with various power cords in the €50-€250 range. It turns out that this LPS is a very nice match with a shielded €57 OFC copper cable.
I recommend this LPS especially with a nice shielded power chord. Best with 1,5m -2m length, in my experience.
Delivery by Audiophonics to Sweden was quick. The LPS is heavy and feels very solid.
Rik H.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Great product!
For the price this thing is great! It's well build, looks good and functions as promised.
Menus are very clear and settings are easy to changes according your personal needs.
The remote also works better then the one from the Topping product I had before.
The display is clear and informative. (brightness is high, so you can set it to the lowest level and it is still readable from a good distance)
But better still: objectively it lives up to the specs the manufacturer shows on the product page. (https://www.audiosciencereview.com/forum/index.php?threads/smsl-raw-mda-1-dac-headphone-amp-review.56430/) It does not sound. It just transforms from the digital domain to the analog and amplifies (actually it attenuates) the signal without any audible artifacts.
CASPAR P.
j'ai du mal à comprendre
Bonjour à tous.
J'ai testé ce câble sur mon installation, Naim supernait3, JMR cantaile jubilé, Atoll MS120.
J'avoue avoir du mal à comprendre les nombreux avis positifs sur ce câble. Il est terne, très mou dans le grave et peu définit dans le médium aigu. Les voix deviennent tristes et les timbre voilés dans un flou à la David Hamilton.
J'imagine que sur beaucoup d'installations, il corrige un coté agressif de l'aigu, Pour moi, le but d'un câble est de transmettre, pas de corriger. Démonté au bout de 50 heures d'écoute.
par contre 5 étoiles pour le service Audiophonics, il est rapide, définit, bref, tout l'opposé de ce câble.
Pierre
GEORGIOS C.
Remarkable sound for a very reasonable price
The plug has all the attributes that i'm looking for, the most important being the PTFE insulation and the direct silver plating. The surprise came when i compared it with the VIBORG VR106G which has solid silver contacts and costs four times the price of the Elecaudio. To my detailed system (costing 15.000€ that are spent very carefuly) their sound is indistiguisable. This is an exceptionaly good sounding RCA plug, which is allso very well made and, to my knowledge, with the highest value/money ratio.
Jean Louis L.
NEOTECH NC-P303G Connector IEC C13 UP-OCC Copper Gold Plated Ø24mm This IEC C13 Neotech NC-P303G IEC C13 connector will allow you to design your own high performance power cables. It incorporates 99.99999% pure UP-OCC copper contacts with 24K...
Timbres juste et grand naturel
Ce connecteur en cuivre pur OCC vient remplacer un déjà très bon connecteur Viborg en cuivre pur OFC, sur un câble Furutech TCS31.
L'écoute après le rôdage habituel montre un progrès net dans le naturel des timbres et sur la reproduction des voix. En association avec le Furutech TCS31, l'écoute est de toute beauté !
Ce connecteur ne montre aucune brillance, c'est le naturel qui s'impose (attention si ce point est important pour vous à la version Rhodium, mais c'est affaire de goût de chacun).
A son tarif, il permet un réel progrès de l'écoute et représente une valeur sure et une référence, pour qui recherche une écoute juste et naturelle des voix, avec des timbres riches et de toute beauté sur des instruments acoustiques, sans la petite brillance et sur-définition artificielle "hifi" que personnellement, je n'aime pas.
Jose Molina Cuerda P.
Mcap
Sonido natural y refinado
Mcap
Mcap
sonido natural y refinado
Eric J.
SMSL A50 PRO Amplifier 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W 4 Ohm + 100W 2 ohm. One of...
Une bonne surprise, avec du souffle
Ma base de comparaison se fait avec Smsl DA-6, Aiyima T9, Xduoo MT-605, Fosi Za3, Aiyima A08 pro, Topping MX3S.
Et des amplis Kenwood vintage qui sont ma préférence jusqu'à aujourd'hui.
Cet ampli sonne brillant, transparent, sans doute la signature des deux MA12070. J'aime bien. Très expressif, peut être trop pour certains. En tonalité direct, les aigus paraissent excessifs, les basses aussi. La rythmique est bien maîtrisée.
Son défaut, c'est que sans musique jouée, il fait du souffle.
Pour le prix, la sonorité, les entrées, la télécommande, la puissance 2X70W présents, je l'ai vraiment apprécié. Et je le préfère en sonorité aux amplis d'Audiophonics, cités plus haut.
Michel V.
SHANLING EC SMART Lecteur CD Vertical Sanyo DA11 CS43131 Bluetooth 5.4 The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC Smart accommodates CDs just...
Elégant lecteur et pratique
Peut se mettre à la verticale ou à l'horizontal. La dynamique est bonne.
Le son délivré par le jack casque et par le BT a de la puissance.
Quand utilisé à plat, les entrées arrières / dessous, ne sont pas très pratiques.
jean-françois v.
Retour d'expérience après rodage - environ 50H
Je tenais à faire un petit retour d'écoute de ces horloges au combien excellentes, cependant après rodage de celles-ci (45 et 49 MHz) installées sur mon Reclocker FIFO PI Q7 II, il apparait ce qui suit :
- Les voix de certains chanteurs étaient auparavant un petit peu sourdes , elles sont bien en place après rodage.
- Tout parait beaucoup plus juste, plus à sa place.
- On gagne de la matière dans le bas médium
- Les graves sont abyssales et très tendus
- Les fins de notes sont hyper silencieuses
Pour finir le plus important, il y a une séparation des canaux et des instruments encore plus marqué, j'ai une stéréophonie qui prend de la largeur comme jamais. Et puis tout ça c'est très naturel, sans crispation ni dureté on en oubli que c'est du numérique !! Produit à acheter pour atteindre les sommets (auparavant j'avais des horloges Accusillicon), le gap est vraiment important entre ces deux horloges !! Bravo à Ian Canada pour le développement de leurs produits qui sont bien au-dessus de la concurrence.
jean-françois v.
Sc Pure après rodage d'environ 50h00
Etienne c.
Dommage
Ampli bon son avec très bonne dynamique.
Problèmes : écartement bornes hp pas normalisées.
diamètre passages de câbles hp très petits.
Bouton power on / off capricieux.
Ampli reçu pas neuf, modèle d'expo ?
Etienne c.
Dommage
très bon ampli neutre et très bonne dynamique .
Les problèmes : espacement des bornes hp pas normalisées .
le diamètre de passage câble hp très petit.
bouton marche arrêt capricieux
Le produit que j'ai reçu n’était pas neuf , modèle d'expo ?
Teddy A.
MUNDORF MLYTIC AG Capacitor 100V 1000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Le meilleur des meilleurs
Utilisé pour upgrader les composants existant dans un DAC déjà excellent (ERATO DAC100V1) c'est incroyable de constater combien les autres condensateurs manque de transparence !!!
david h.
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is...
haut parleur
les meilleur pour un pincab et le service audiophonics du tonnere
Emmanuel A.
Bien meilleur que d’autre très cher
J’ai essayé de nombreuses grammes de Câble pour des connexions modulation sur mon système Attol in 300 Avec streamer et lecteur, ainsi que Dac, de très bonnes factures sur l’ensemble, des cables testés du commerce et ce que j’ai fait fabriquer ce modèle m’a donné la plus grande satisfaction, il est supérieur À l’autre modèle de cette marque, le l2-t2s a beaucoup plus de détails, je trouve le moins montant que le L-4E6S
Pour les avoir tous les deux testés en alternance
Bruno C.
BERRYBAK BEA 1 R2CEPTEUR BLUETOOTH
Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
Paulo A.
This is a tiny, cheap pre amp phono that i bought to replace a broken NAD ... and it sound very very clear and cristal. For the price it is a great product! Love fosi brand.
Paulo A.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
I put this new tube in my Xduuo 605 amp and the sound is fantastic... very good. It's an huge upgrade from the original tube at a very nice price!
Paulo A.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
Fantastic little amp
This is a great little amp. I love tube amps and the warm sound ...this one is a super budget hifi piece. I roll to a new tube (thanks for the tip) a Tung Sol and it just sound amazing. Great mids and highs, bass is very smooth but present. The sound is vey neutral and warm ... just fantastic
iouri C.
PSVANE EL34-Z Power Tubes (Matched Pair) PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture...
Superbes !
Ces tubes sont magnifiques ! Je ne parle pas du coffret, de l'écrin grande classe dans lequel ils arrivent. Acheté en deux fois deux appairés pour mon primaluna prologue one. J'ai des el34 jj versions 1 et 2, des Mulard 6450, des lion gold KT 88... J'ai débuté avec psvane sur deux 12ax7 puis deux 12AU7 qui ont remplacé des mulards et jj la aussi. Maintenant tout est en psvane. Si j'aime le son des kt88 je les trouve trop "modernes" en son. Avec lrs psvane el34z, je retrouve le grain des el34 série 2 de jj mais avec un son plus analogique et surtout une présence et détails dans les voix, des harmoniques... C'est assez fabuleux alors qu'ils n'ont pas encore tourné plus de 25 heures environ. A voir ou plutôt entendre si ils se bonifient encore !
hugues O.
Ethernet to Optical Fiber Converter (Pair) IEC Power Supply This device converts a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit...
Fibre
C’est le premier et le moins cher des convertisseurs optique qui fonctionne chez moi. Je ne sais pas si c’est dû à la fibre monomode. Ne pas oublier de commander une fibre monomode si vous n’en avez pas et des câbles IEC. SHUKO
Hocine H.
Sceptique, mais...
Je devais changer la double prise qui alimente mon système, je me suis dit cher, mais pourquoi pas. J'étais sceptique, voire je n'attendais rien de particulier ; et pourtant quelle claque. Ce n'est pas le jour et la nuit, mais tout est plus limpide, détaillé. Alors comme j'ai une double prise juste à côté, j'ai pu faire la différence et non je ne rêvais pas, il y a bien un avant et après avec cette prise Furutech et si je devais tout recommencer de 0, c'est la première chose que je changerai, n'hésitez pas, vous ne le regretterez pas, cette double prise change votre perception de la musique.
Sylvain M.
Super streamer. Je ne suis pas audiophile, mais je peut dire que le son est très bon, détaillé, les basses profondes. Un appareil qui s'oublie (avec une bonne application) : pas d'affichage superflu, et une petite taille parfaite pour le cacher dans un meuble. Je recommande !
stoica r.
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
Antonio D.
Três bom cable. Bonne construction et trés neutre au niveau son.
Juha T.
Excellent quality
Build quality really good, excellent sound. Although the case is small and lots of power, amplifier case heats only little during modest levels of listening.
George A.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Τα αρνητικά ... είναι η μικρή οθόνη δεν βλέπεις αριθμό κομματιού και χρόνο από θέση ακρόασης, και δεύτερον δεν έχει πλήρες αριθμολόγιο 0 έως 9 πού έχουν τα cd players. Επίσης αργεί λίγο να πάρει εντολή στο πάτημα των κουμπιών του. Δηλ. δεν προδιαθέτει για εναλλαγή κομματιών με το γνωστό τρόπο, σταμάτα ξεκίνα κτλ. Προσωπικά δεν έχω θέμα με όλα αυτά... μπορεί για κάποιον να είναι αρνητικά...
George A.
Shanling cd transport cr 60 + musical fidelity v90 dac. Είχα rotel cd 965, cabridge cd azur 640; Τα ξεπερνάει εντελώς! Υπέροχη στερεοφωνία, ανάλυση αβίαστη απεικόνιση, αθόρυβο εκτός και ο δίσκος είναι άκκεντρος; (Σε ελάχιστα cd). Αρκετά βαρύ (Φούλ αλουμινένιο κουτί και παχύ!!) βλέπεις τα χρήματά σου με το παραπάνω. Με ποιοτικό τροφοδοτικό είναι το κάτι άλλο!
le meilleur de fosi
achetés puis revendus pour fosi v3 mono, je regrette cet echange. Meme si v3 mono est plus propre sur le signal, le plaisir d' écoute( spacialisation, detail, relief) est bien meilleur sur les za3
nickel
cet etain allié a l' argent est super a travailler et les soudure sont propre et brillantes. Apres plusieurs essai de marque, je retiens en definitive celle ci.
tout simplement le meilleur rapport qualité prix en matière de fiche xlr.
bien et jolies
bonnes fiches bananes mais suivant le bornier, on peut être ennuyé pour les enficher.
MUNDORF ACS1150GY ANGELIQUE Wiring Cable Copper / Silver / Gold 1.5mm² Grey Mundorf ACS1150GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
usage bien précis
J' ai voulu essayer ce câble pour un câblage interne de 'un ampli en liaison HP, a lui seul, il ne convient pas pour cet usage . En effet, il excelle dans le haut médium et les aigus mais trop maigre pour des basses dignes de ce nom.
parfaite
Tout comme les fiches bananes de cette marque présentes sur ce site, ces fourches sont de très bonne qualité, je les recommande.
tres moyen
J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
top
ces fiches rca sont parfaites en tous points. faciles a souder, légères et peu encombrante et transmission du signal intègre.
elles font souvent partie des choix des grandes marques de câbles.
parfaite
je epnsais que jantzen était une marque chinoise proposant des produits de qualité moyenne.
Il n' en est rien. C' est une société suédoise qui propose dew produits de treès bonne qualité à un prix ultra compétitif. Ces fiche en sont la preuve. elles sont jolies, bien calibrées et le serrage est parfait meme en faible section. Leur design minimaliste offre une finition hi end. je recommande ces fiches sans hésitation.
Patrice T.
HIDIZS S9 PRO PLUS MARTHA Portable Balanced DAC Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 Black Hidizs unveils its S9 Pro Plus Martha, an evolution of the S9 Pro, a powerful, high-performance balanced portable DAC headphone amplifier. It features a fully balanced...
Impec !
J'ai acheté ce DAC sur les conseils d'Audiophonics que je remercie vivement. Dans un budget contenu je voulais dépenser pas plus d'une centaine d'euros pour essayer ce type de matériel que je trouve désormais indispensable.
Il ne fonctionnait pas avec mon Samsung S23 Ultra, j'ai donc écrit chez Hidizs qui m'ont répondu très rapidement et de manière bienveillante, je les remercie également de fournir un support de qualité. Finalement il s'est mis à fonctionner. Pour info il fonctionne sous Windows 11.
Il faut absolument respecter le sens du câble, le logo sur la prise du smartphone.
Que dire...c'est mon premier DAC donc pas de comparaison possible. Je ne vais pas parler de la profondeur du grave, de la transparence des aiguës et j'en passe, non...je vais simplement dire que je suis très satisfait de la restitution, de sa limpidité, d'une bonne musicalité qui me satisfait pleinement. Sur Qobuz c'est magique en Hi-Res.
Il faudrait que j'essaye un jour un DAC 5 fois plus cher pour comparer. Il y a peut-être mieux mais je n'en sais rien...
Le logo sur le DAC s'allume dans une couleur en fonction de l'encodage du fichier lu, c'est du plus bel effet.
Il est petit léger, les boutons volume pratiques, belle construction, bel achat.
Loic T.
pour mon khadas tone2 pro
fonctione parfaitement, impecable !!!
Michal L.
AUDIOPHONICS Trigger 12V 230V Slave Power Supply Device This accessory, made in France in our workshops, makes it easy to add an automatic ignition (trigger) function to your devices that don't have this feature natively.
Good
Works/performs as expected. However I must confirm this - from another review: "Another con is the tolerances of the connectors - the plug side is tiny bit too small and tends to wobble when plugged in and the connection does not feel as secure as it should. Same goes with the input side which is a bit too loose."
Amaral E.
Phenomenal
Phénoménal Câble fabuleux à tous les niveaux, gamme de fréquences étendue, séparation instrumentale, image 3D immense. Une grande transparence conserve cependant un raffinement et une émotion appropriés sans jamais paraître analytique ou froid. Câble très bien construit avec maille de cuivre occ, une bénédiction, les deux conducteurs étaient reliés au point positif et la maille au négatif. Une partie de la magie de ce câble peut être due à la nouvelle technologie consistant à ajouter du graphène aux conducteurs. Pour moi, c'est le meilleur que j'ai jamais entendu et j'ai entendu de nombreux artistes de haut niveau comme Kimber kS et Nordost Heindall par exemple. Bien entendu, les meilleurs câbles du futur devront utiliser du graphène. Neotech a pris la tête de la révolution technologique en matière d'excellence en matière de conduite électrique. Les nouveaux câbles d'enceintes devraient avoir les mêmes vertus sonores. Cela vaut le prix élevé, mais cela vaut chaque centime. envoyé un SMS du CD au pré aux vannes et du pré à un moteur Rotel RB 1552.
Fabien A.
Peut-être l'élément le plus important de toute installation hifi. Une fois monté, j'ai l'impression que tous les éléments de mon installation sont montés en gamme. Un bien meilleur rendu général, plus de transparence, un gain sur la scène sonore, en largeur et profondeur. Un grave plus net et profond et de la matière dans le médium. Je suis très satisfait de l'amélioration apporté par cette prise. Et pour le montage murale, j'ai utilisé les plaques proposées par audiophonics spécialement adapté à ce modèle qui m'a permis de monter la prise sans pb dans mon mur et avec un rendu visuel très sympa.
Fabien A.
Wall Plate Aluminum base plate Schuko for FURUTECH FI-E30 Black We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
Merci à l'équipe Audiophonics de proposer cette plaque parfaitement adaptée à la prise furutech E30, dans mon cas le modèle NCF. La finition est au top pour un super rendu une fois monté.
DIMOKRITOS D.
Best souding plug for the money, and more
In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
jean-françois v.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
Upgrade Alim Linear PI pour 5V du FIFO PI Q7 II
Petit retour d'expérience sur ces supercondos de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de cet upgrade de supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada, tout ça pour alimenter le reclocker FIFO PI Q7 II !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet upgrade j'ai aussi changer les Horloges de mon reclocker FIFO PI Q7 II par des SC Pure, Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en construisant mon propre système, voilà pour mon avis perso. Si cela peut servir pour prendre des décisions dans des réalisations futures, c'est plutôt cool.
Jean-François.
AUDIOPHONICS GXDC-21 Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can be used with LHY power...
Mettre un Olflex secteur en amont de cette trés bonne alim.
Le câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC (pour Alimentations LHY) fourni avec cette alim fournissant du 15v, est correct.
Par contre, le câble secteur IEC en amont de 3x0.75mm2 fourni d'origine, est une vraie daube, il gâche vraiment cette alim qui est au demeurant excellente.
Je recommande donc fortement d'utiliser à cet endroit un Olflex de 3x1,5mm2, lequel apporte une lumière et une transparence des plus agréables.
Dominique M.
Bi amplification
Difficile à monter,pas d’indications de montage,faut-il garder les fils argentés ou les supprimer comme le montre une vidéo you tube?dans l’expectative je l’ai les enroulées autour du cuivre.
Des précisions de montage de la part d’ audiophonics seraient bienvenus au prix de ce câble.
Ceci dit je ne regrette pas cet achat,le son est vraiment bon sur tous les critères.
Un avis de quelqu’un en ayant aussi l’expérience en France peut être ?
Theodore A.
EIZZ EZ-213 XLR 3 Pin Male and Female Connectors Rhodium Plated Ø10mm Black (Pair) This pair of EIZZ EZ-213 XLR connectors consists of one male and one female XLR connector. They feature 99.99% pure copper contacts with non-magnetic rhodium plating.
Very good connector
Sound is really good, not however like the top connectors, there is a difference. For the money however the sound worths every penny.
My problem is that I used 10mm cable and the fixing screws, either sunk (had to put extra sleeve to reach 11mm) or in two cases the plastic where the screws reside was broken. Its a pity. My recommendation to EIZZ. Put an extra hardened plastic ring where the screws will reside and make them a little longer.
